SimonG3
  • 9
Message 1 of 18
Recently upgraded to 350, speed reverted back to what i had before?
I recently Upgraded to 350 from my old package. Speed was fine for a few weeks at 300+mbps download and 30+ upload. 1 day it randomly reverted back to the speeds of my old package and now I'm stuck at 10mbps download and 1.5mbps upload?
any ideas?
thanks
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 18
Re: Recently upgraded to 350, speed reverted back to what i had before?
How are you connecting Wi-Fi or ethernet cable ?
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Can you set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub, it will take a few hours to get any kind of trend showing although you can post the link straight away.
 In the URL box paste the link you copied and then click OK - you can post the link straight away.
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow warning click the Post button again.
SimonG3
  • 9
Message 3 of 18
Currently using ethernet cable.
no know issues on service statues or the help line.
Co-ax all secure and finger tight.
BQM set up and will link once i have data.
router is as follows:
configuration:
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
oA,.iyewrkldJKDHSUBsgvca69834nc
SFID132
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID131
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
SimonG3
  • 9
Message 4 of 18
downstream:
16670000002.538256 qam33
24910000001.738256 qam11
34990000001.737256 qam12
45070000001.738256 qam13
55150000002.238256 qam14
65230000002.537256 qam15
75310000002.538256 qam16
85390000002.538256 qam17
95470000002.238256 qam18
105550000001.738256 qam19
115630000001.738256 qam20
125710000001.438256 qam21
13579000000238256 qam22
14587000000238256 qam23
155950000002.538256 qam24
16603000000338256 qam25
17611000000338256 qam26
186190000002.738256 qam27
196270000002.738256 qam28
206350000002.238256 qam29
216430000002.738256 qam30
226510000002.238256 qam31
236590000002.538256 qam32
246750000002.538256 qam34
1Locked38.648271053
2Locked38.651381640
3Locked37.651391751
4Locked38.651561347
5Locked38.652091357
6Locked37.651971099
7Locked38.652351069
8Locked38.651401016
9Locked38.650561187
10Locked38.649671320
11Locked38.650621463
12Locked38.650561417
13Locked38.950851458
14Locked38.950031222
15Locked38.950591097
16Locked38.949271000
17Locked38.94978949
18Locked38.64990814
19Locked38.94998738
20Locked38.94972964
21Locked38.647621073
22Locked38.647861188
23Locked38.947081090
24Locked38.64742940
SimonG3
  • 9
Message 5 of 18
up stream:
1462000974.425512064 qam1
2257999814.275512064 qam4
3326000004.275512064 qam3
4393999814.425512064 qam2
3ATDMA0000
4ATDMA0000
SimonG3
  • 9
Message 6 of 18
network log:
11/08/2020 18:06:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/08/2020 18:03:52noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/08/2020 17:44:51Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/08/2020 05:46:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/08/2020 11:05:52noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/08/2020 11:05:52ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/08/2020 08:38:10ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/08/2020 08:26:24criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/08/2020 01:15:12ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/08/2020 00:50:47criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/08/2020 15:24:35ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/08/2020 07:59:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/08/2020 02:19:35Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/08/2020 21:32:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/08/2020 15:13:22noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/08/2020 15:13:22ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/08/2020 07:43:19ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 20:38:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/07/2020 23:35:9Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/07/2020 23:35:9criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Anonymous
Not applicable
Message 7 of 18
Well your config file is correct at least!
SFID132
Min Traffic Rate0
SFID131
Min Traffic Rate0
The stats, other than the network log, look ok. There are quite a lot of 'Pre RS' and 'Post RS' Errors, however I don't know how long your HUB has been on since the last reboot.
It could be an oversubscription in your area.
It would be worth setting up a BQM, as Mike already suggested, so we can see the quality of the line:
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 18
You can post the link to the Live BQM straight away.
You have quite a few Post RS Errors, how long since you last rebooted the Hub ?
In fact it may be as well rebooting the Hub at the first opportunity, make a note of the time so that we can see the corresponding red line on the BQM.
SimonG3
  • 9
Message 9 of 18
I rebooted my hub just before posting on the forum. I also tried resetting it back to its factory settings to see if that would help.
The errors at 6pm ish are most likely the same time I tried this.
BQM
I have not rebooted since creating the BQM but will notify any times I do from now on.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 18
Your Post RS Errors have gone up significantly if the reboot at 18:00 put them back to zero.
Your BQM isn't showing any reboots, in fact up to now [21:15] it is looking very good.
