urbanbumpkin
  • 58
  • 6
Dialled in
Message 1 of 16
Recent updated to 200Meg Slower than before. 67down and 0.51 up
I've recently upgraded from 100 Meg to 200meg broadband. I'm currently getting 67down and 0.51 up. I've rebooted the router on a number of occasions but it's still the same speed.
Any suggestions?
Tags (1)
urbanbumpkin
  • 58
  • 6
Dialled in
Message 2 of 16
Re: Recent updated to 200Meg Slower than before. 67down and 0.51 up
I've logged a fault with Virgin Fault have provisionally been told there is a fault, received a text to say there wasn't any issues and then spoke to someone who believed there was and it would be rectified by March the the 10th
  • 15.86K
  • 2.1K
  • 4.98K
Message 3 of 16
Hi @urbanbumpkin
The fault may show up on the automated Service Status number  0800 561 0061.  This often gives details of more local issues down to postcode level.
Dave
Love, love and love, forever - Pele
Paulina_Z
  • 5.09K
  • 190
  • 397
Message 4 of 16
Hi @urbanbumpkin,
Welcome back to our Community Forums! Thank you for your post and I'm very sorry to hear that you're having some speed issues after your upgrade!
Have you been able to reset your Hub to see if this can help show your new speeds? I was able to run some checks on our systems and I cannot see any issues that could be impacting your service at the moment. There are no active area issues that could be impacting you. The area fault that was recently active was resolved on 04/03/22.
Please complete a reset and let us know if your speeds have come through. It's best to run checks on a wired connection as well for best results. 🙂
Keep us updated.
Thank you.
Paulina_Z
urbanbumpkin
  • 58
  • 6
Dialled in
Message 5 of 16
Thanks for the reply. The internet connection is a lot more stable. However I’m only consistently getting 126 meg down. Up is good though 20 which I believe is what it should be
Lee_R
  • 6.89K
  • 326
  • 736
Message 6 of 16
Hi @urbanbumpkin thanks for getting back to us.
In regards to the speeds your receiving, more so around the downloads, can you advise if this is via a wired or wireless connection?  If wireless, would you be able to do a hard wired test on a PC/Laptop?
Lee_R
urbanbumpkin
  • 58
  • 6
Dialled in
Message 7 of 16
I’ve just tried wired and I’m getting 113 down and 16 up.
I did try wireless when it was first set up and I was getting over 200 down and 20 up
Carley_S
  • 3.1K
  • 163
  • 263
Message 8 of 16
Sorry to hear this issue is still ongoing for you @urbanbumpkin
I have taken a look at our systems and can see no issues at our end or in the area.
Can you confirm what device and OS you are using to run a speed test and what speed test site you are using?
Please make sure that the device you using to run the speed test is also fully updated with it's software and drivers.
Carley - Forum Team
urbanbumpkin
  • 58
  • 6
Dialled in
Message 9 of 16
I'm still getting the same issues. I did receive a text about essential maintenance work that was taking place yesterday. I'm running this on a laptop using Microsoft. Since having the upgrade to 200 I've only managed to have 1 speed test that's resembled this speed it should be.
iPhone is exactly the same
What can you see from your side?
Zach_R
  • 4.9K
  • 159
  • 336
Message 10 of 16
Hi @urbanbumpkin,
Thank you for getting back to us on this. I've just checked things on our end again and there are no faults currently being detected on the line to explain this. Is this ongoing for you today?
If it is, I understand from your last post that you're running the speed test on your laptop, but is that through a wired connection? If it isn't, can you run one and let us know the results?
Let us know how you get on either way.
Zach - Forum Team
