Recent speed upgrade has killed my upload speed
craigfritzsche
Just joined
Restarted hub as per email re the free speed increase. (100Mbps > 125Mbps download and 10Mbps > 20 Mbps upload).
Download seems to have increased, although results vary by speed checking platform. To be honest it makes no difference - it was plenty quick enough before.
However, my upload speeds vary from 0 - 0.9Mbps. Basically it's just stopped. It was consistently over 10Mbps before the 'upgrade'. It makes it impossible work.
I've checked everywhere - 'no problems in my area'. I've reset the hub.
Anyone else had this 'upgrade' issue. Any fixes out there?
Thanks.
1 ACCEPTED SOLUTION
Accepted Solutions
see this
_________
A pinhole reset of the Hub has solved this for many customers - so do this...
____________________________________________________________
Do a Hub “pinhole reset” - first make sure the 2 passwords on the Hub sticker are still there and legible first ! Disconnect any ethernet cables from the Hub (leave the coax connected), and then with the Hub still "switched on" throughout, press pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 (a timed sixty) seconds, release the pin, leave for 5’ to stabilise - dont manually switch it off at any time. Passwords and SSID’s will reset to those on the sticker.
See if that sorts it.
I do not work for VM. My services: HD TV on VIP (+ Sky Sports & Movies & BT sport), x3 V6 boxes (1 wired, 2 on WiFi) Hub5 in modem mode with Apple Airport Extreme Router +2 Airport Express's. On Volt 350Mbps, Talk Anytime Phone, x2 Mobile SIM only iPhones.
1 REPLY 1
see this
_________
