Recent gig1 and hub 5 upgrade, slow download speeds on Xbox
ehsanr22
Today I got the upgrade to Gig1 from 500mb and a hub 5 router.
I am using wireless xbox connection as dont have an ethernet cable long enough to connect to the router and my download speeds are exactly the same as I was getting with the 500mb package, around 100mbps in xbox download speed.
I need help sorting this out please as there’s no point me upgrading to gig1 if the download speeds are the same and I might aswell just cancel within my 14 days if I can’t get it sorted.
Thanks!
19 REPLIES 19
ehsanr22
Now i’m only getting 50mbps on xbox downloads which is the slowest speed i’ve ever had with Virgin
What does this site show?
https://speedtest.samknows.com/
jb66
Your xbox isn't capable of getting 1gig over wifi, you may as well downgrade as your not making the most of the speed
Hi, thanks for the response, results shown below:
Hi, of course I was never expecting 1gig or near on the Xbox at all, but I have friends and family who at least get 5-600 minimum through their xbox whilst i’m on 100 currently
Get a Cat 6 cable as a test and see what the results show.  1GB connection should top out at around 940.
As for Wifi, do an environment survey with a wifi scanner and see what the issues are.  It could just be you need better wifi to get the best out of your XBox.
Legend
On M500 80% of the VM service was unavailable to the XBOX due to the use of Wi-Fi.
Upgrading to Gig1 was not a smart move.
So why do others I know on Wi-Fi using Xbox get around 500-600mbps?
I cannot see the image as yet.
What speed is displayed on the left (Speed to the HUB over the VM network)?
