Danfrench36
Message 1 of 5
Really inconsitent broadband speed
Network LogTime Priority Description
03/10/2021 16:47:48noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2021 16:47:32Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2021 16:19:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/09/2021 20:32:8ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2021 01:04:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/09/2021 20:32:8ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/09/2021 17:59:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/09/2021 08:32:8ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/09/2021 22:49:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/09/2021 20:32:8ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/09/2021 08:50:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/09/2021 20:32:8ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/09/2021 08:47:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/09/2021 20:32:8ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2021 21:51:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/08/2021 11:56:33ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2021 17:36:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2021 15:09:47ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2021 14:53:12Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2021 14:53:12criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Danfrench36
Message 2 of 5
Re: Really inconsitent broadband speed
13307500004.537256 qam25
2202750000237256 qam9
32107500002.437256 qam10
42187500002.537256 qam11
52267500002.537256 qam12
62347500002.437256 qam13
72427500002.537256 qam14
82507500002.537256 qam15
92587500002.737256 qam16
102667500003.437256 qam17
112747500003.937256 qam18
12282750000437256 qam19
13290750000437256 qam20
14298750000437256 qam21
15306750000437256 qam22
163147500004.438256 qam23
173227500004.537256 qam24
183387500004.337256 qam26
193467500004.138256 qam27
20354750000438256 qam28
21362750000438256 qam29
22370750000438256 qam30
233787500003.937256 qam31
243867500003.538256 qam32
1Locked37.6260
2Locked37.6820
3Locked37.31070
4Locked37.6410
5Locked37.6440
6Locked37.6760
7Locked37.3730
8Locked37.3720
9Locked37.6450
10Locked37.3410
11Locked37.3300
12Locked37.3390
13Locked37.6410
14Locked37.6170
15Locked37.6130
16Locked38.6110
17Locked37.3390
18Locked37.6170
19Locked38.6130
20Locked38.6290
21Locked38.6400
22Locked38.6310
23Locked37.6220
24Locked38.9220
Danfrench36
Message 3 of 5
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
13940000043.3512064 qam6
24620003043512064 qam5
33260000043.3512064 qam7
42580003943.3512064 qam8
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1ATDMA0030
3ATDMA0000
4ATDMA0000
jpeg1
  • 6.68K
  • 344
  • 1.22K
Legend
Message 4 of 5
Nothing much wrong there.  What device are you using to measure the speed, and how is it connected?   WiFi speeds are not guaranteed.
Zoie_P
  • 4.67K
  • 196
  • 360
Message 5 of 5
Hi Danfrench36
Thank you for your post.
I am sorry to hear you are having broadband speed issues, I have checked your account and power levels and all looks fine if you could answer @jpeg1's this would help us a lot to figure out more about your issue 🙂
Zoie
