jcev39
  • 9
Message 1 of 18
Really fed up with connection speed (M500)
I've recently moved house and was offered an upgrade to M500.  Unfortunately, apart from the day it was installed I can't get a speedtest.net result higher than over 35Mbps, it's usually down around 20Mbps and has been as low as 2! With 2 of us on work video calls, it is continually glitching which suggests these are realistic figures and I'm really getting it in the neck from my wife!!
Whilst I'm fairly tech savvy, I'm really not up to speed with the technical requirements of Wifi networks etc. so any help would be greatly appreciated.
As suggested I've attached copies of the download, upload and network logs below.Downstream.jpgNetwork.jpgUpstream.jpg
Tags (2)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 18
Re: Really fed up with connection speed (M500)
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
jcev39
  • 9
Message 3 of 18
Following your instructions I got 347 Mbps down, 37 up.  Connection speed 1000.  What's weird is that immediately after I used the same app on my phone and got 17.6 Mbps down and 27.3 up (approx 1m from the router).
I'm now stumped!  Can't run network cables throughout the house (well I could but that wouldn't make me popular) so need the speed via wifi...
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 18
You need to get a Gigabit enabled Wi-Fi Router or a Mesh system to give you better Wi-Fi coverage.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 5 of 18
Please post a 'Live Link' to your BQM on here.
jcev39
  • 9
Message 6 of 18
Isn't the Virgin router Gigabit enabled?  Seems a bit odd if it isn't!
I'll look into the suggestions though. Many thanks
Anonymous
Not applicable
Message 7 of 18
You need to check the 'Connected Devices' section to see what speed your phone is connected at.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 8 of 18
Yes it is, so anything that attaches to it also needs to be Gigabit capable.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 9 of 18
Deleted.
jcev39
  • 9
Message 10 of 18
As requested the Thinkbroadband quality graphs link thinkbroadband broadband monitoring quality
