nisartahir
Re: M350 speed not achieved - same problem for someone else extremely bad service
i was on 100 services it was very bad so i upgraded to 350 services for the cooling-off period the service was 2 good to be true I was happy
last night at 3 am lost the broadband service it came back in 1 hour now I am receiving 85 to 92 I complained to virgin media and they are
can even test from there side why I get the speed they think by giving me 20 pounds will resolve it the thin is I am paying for 350 all I want is 350 the price i am paying for
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Please post a 'Live Link' to your BQM on here.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
