Galveo
Random speed drops
Hi Everyone,
I currently have a pretty simple setup with Virgin Media in the UK. I have a UDM (Unifi Dream Machine) and a super hub 4.0 in modem mode plugged into the UDM.
I have a 550/50 connection and most of the time it runs at this speed with no issue.
However at random intervals my speed will drop down to 40/27 and you won't be able to get any faster than this speed. The only thing that fixes this issue temporally is by restarting the modem and it will go back to the full speed.
I can't work out what's causing this issue and have tried numerous diagnostic steps:
  • Factory Reset Modem
  • Replaced Ethernet cable from modem to router.
  • Replaced Superhub with a new model. Issue apparent on Superhub 3.0 and 4.0
  • Tried a new router (Amplifi Gamer's Edition)
Any help would be really greatly appreciated.
[MOD EDIT: Subject title changed for clarity]
Steven_L
  • 11.32K
  • 685
  • 1.15K
Re: Random speed drops
Hey @Galveo,
Welcome to the community and thanks for taking the time to post your issue on the forums.
I'm sorry to hear that you're facing issues with your connection at the moment.
Do you have any issues, if you run the hub in router mode rather than modem mode?
Would you be able to setup a BQM to help monitor your connection and this can also help us diagnose the issues with your connection. You can set this up here https://www.thinkbroadband.com/broadband/monitoring/quality and if you can post back in a few days, this will show us any issues that you're having with your connection.
Also, please could you post your hubs network logs on this thread, you can access this  In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) and hit return. On the first page up [there should be no need to login if you have done so before]
click on the “router status” icon/text at bottom-middle of first page up and then copy/paste 3 FULL sets of data onto here – from the Downstream, Upstream, & Network Logs pages.
Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses.
Regards,
Steven_L
Galveo
Thanks for your reply.
I have setup a BQM which can be found on the link below:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/49a067930be95595d60cd7f1dbff7972ce993a3b
Please also find the router status details as requested.
Downstream:
26339000000-7.09999838.983261QAM25626
1139000000-5.79999938.983261QAM2561
2147000000-5.59999838.983261QAM2562
3155000000-5.79999938.605377QAM2563
Upstream:
3.0 Upstream channels
12580000052.5205995120 KSym/sec64QAM6
23260000052.7705995120 KSym/sec64QAM5
33940000052.7705995120 KSym/sec64QAM4
44620000053.2705995120 KSym/sec64QAM3
Network Log:
Wed Apr 13 14:49:12 20226CM-STATUS message sent. Event Type Code: 5; Chan ID: 13; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 14:49:13 20225Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 14:49:15 20226CM-STATUS message sent. Event Type Code: 4; Chan ID: 5; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 14:52:47 20225Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 14:52:55 20226CM-STATUS message sent. Event Type Code: 4; Chan ID: 5; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 14:55:07 20225Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 14:55:32 20226CM-STATUS message sent. Event Type Code: 1; Chan ID: 11; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 14:55:45 20225Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 14:55:47 20226CM-STATUS message sent. Event Type Code: 1; Chan ID: 11; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 14:56:21 20225Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 14:56:21 20226CM-STATUS message sent. Event Type Code: 1; Chan ID: 11; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 14:57:31 20225Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 14:57:32 20226CM-STATUS message sent. Event Type Code: 5; Chan ID: 13; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 14:57:41 20225Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 14:57:50 20226CM-STATUS message sent. Event Type Code: 5; Chan ID: 13; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 14:57:53 20225Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 14:57:54 20226CM-STATUS message sent. Event Type Code: 5; Chan ID: 13; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 15:04:19 20225Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 15:04:40 20226CM-STATUS message sent. Event Type Code: 5; Chan ID: 13; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 15:07:05 20225Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 15:07:13 20226CM-STATUS message sent. Event Type Code: 5; Chan ID: 13; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 15:23:09 20225Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 15:23:28 20226CM-STATUS message sent. Event Type Code: 5; Chan ID: 13; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 15:29:47 20225Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 15:29:53 20226CM-STATUS message sent. Event Type Code: 5; Chan ID: 13; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 15:30:25 20225Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 15:30:54 20226CM-STATUS message sent. Event Type Code: 4; Chan ID: 5; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 15:31:09 20225Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 15:31:29 20226CM-STATUS message sent. Event Type Code: 5; Chan ID: 13; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 15:35:49 20225Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 15:36:13 20226CM-STATUS message sent. Event Type Code: 5; Chan ID: 13; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 15:36:15 20225Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 15:36:17 20226CM-STATUS message sent. Event Type Code: 5; Chan ID: 13; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 15:41:09 20225Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 15:41:20 20226CM-STATUS message sent. Event Type Code: 4; Chan ID: 5; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 15:41:25 20225Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed Apr 13 15:41:26 20226CM-STATUS message sent. Event Type Code: 5; Chan ID: 13; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Apr 14 08:20:11 20223No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Apr 14 08:36:11 20226CM-STATUS message sent. Event Type Code: 5; Chan ID: 13; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Apr 14 11:52:21 20225MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Apr 14 11:52:26 20225RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Apr 14 11:52:30 20225Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Apr 14 11:52:51 20226CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Apr 14 11:52:58 20225Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Apr 14 11:53:04 20226CM-STATUS message sent. Event Type Code: 5; Chan ID: 3; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Apr 14 11:53:10 20225Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Apr 14 11:53:13 20226CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Apr 14 11:53:30 20225Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Apr 14 11:53:43 20226CM-STATUS message sent. Event Type Code: 5; Chan ID: 3; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Apr 14 11:56:27 20225MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Steven_L
  • 11.32K
  • 685
  • 1.15K
Thanks for coming back to us @Galveo.
I have looked into this and can see an issue with your downstream channels on our system that would need a technician visit to resolve.
I can arrange the appointment from here but would need to confirm a few details via a private message, that I will drop over in a moment.
Please look out for the private message and we can get started.
Regards,
Steven_L
Galveo
PM Has been sent, thank you.
Steven_L
  • 11.32K
  • 685
  • 1.15K
Thanks for confirming your details via private message @Galveo.
I have arranged for the appointment and you can track your engineer appointments online. Simply sign in to My Virgin Media and you’ll see your appointments on your account dashboard.
Regards,
Steven_L
