jezwest
Message 1 of 8
RCS partial service, Lost MDD Timeout, slow speed
Hello.
I'm getting very slow download speed, 10Mbps rather than usual 200Mbps (tested with fast.com, speedtest.net) using wired connection. I've done a hard reset and a few reboots and nothing's changed with my hardware / cables.
In the logs I can see this:
20/06/2020 23:08:54Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/06/2020 23:06:7Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/06/2020 22:59:23Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Any ideas of how to fix this please?
Cheers, Jeremy.
Tags (1)
Roger_Gooner
  • 6.41K
  • 468
  • 1.11K
Hero
Message 2 of 8
Re: RCS partial service, Lost MDD Timeout, slow speed
Power off the hub, check that all cable connections are tight from the hub to the wall socket and power the hub back on. If you still have a problem copy and paste the downstream, upstream and network log (mask any WAN IP address).
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
Andruser
  • 5.54K
  • 971
  • 2.28K
Message 3 of 8
If possible, post the Downstream data before powering off.  When you power-cycle a Hub 3 that clears the error counters, and after it's restarted the few pre-RS startup errors won't tell us much.  If it's already too late, then keep and eye on them - you shouldn't have any post-RS errors on a properly working connection after a day (or even two) of continuous running.
jezwest
Message 4 of 8
Hello.
Thank you both for your replies. I'll do that now. Beware....lots of numbers to follow!
Here are the figures before powering off and checking the cable from wall to router:
21/06/2020 07:05:52Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 07:05:51Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 05:26:49Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 05:26:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 05:06:30Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 05:06:11Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 05:05:37Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 05:05:33ErrorService Delete Response rejected - Invalid Transaction;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 04:16:13Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 04:16:2Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 04:13:52Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 04:13:17Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 03:47:7Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 03:45:3ErrorDCC-ACK rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 03:38:54Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1330750000-1.237256 qam25
2266750000-0.537256 qam17
3274750000-136256 qam18
4282750000-1.436256 qam19
5290750000-0.736256 qam20
6298750000-1.735256 qam21
7306750000-1.536256 qam22
8314750000-0.936256 qam23
9322750000-1.537256 qam24
10370750000-335256 qam26
11378750000-235256 qam27
12386750000-336256 qam28
13394750000-2.733256 qam29
14402750000-237256 qam30
15410750000-2.237256 qam31
16418750000-237256 qam32
17426750000-1.737256 qam33
18434750000-237256 qam34
19442750000-2.236256 qam35
20450750000-237256 qam36
21458750000-2.737256 qam37
22466750000-2.737256 qam38
23474750000-2.437256 qam39
24482750000-3.524256 qam40
1Locked37.3232650
2Locked37.62528284
3Locked36.3140669278
4Locked36.346128111
5Locked35.730640217290180
6Locked3535676336561794
7Locked36.19518130295
8Locked3712222702888764
9Locked37.33335318
10Locked35.5318509
11Locked34.9480249365
12Locked36.61027959
13Locked32.9617760135
14Locked37.39002
15Locked37.3348794968
16Locked37.3121071
17Locked37.314734
18Locked37.69191731
19Locked37.39704
20Locked37.353692
21Locked37.3285370
22Locked37.6651711
23Locked37.6649050
24NotLocked37.3254930
jezwest
Message 5 of 8
Here are the figures after powering off, unscrewing the cables, wobbling them gently and screwing them back tight and powering on and the speed is good again:
21/06/2020 11:23:6noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1330750000-1.238256 qam25
2266750000038256 qam17
3274750000-0.538256 qam18
4282750000-0.238256 qam19
5290750000-0.737256 qam20
6298750000-0.737256 qam21
7306750000-0.938256 qam22
8314750000-138256 qam23
9322750000-0.738256 qam24
10370750000-238256 qam26
11378750000-1.737256 qam27
12386750000-2.238256 qam28
13394750000-1.738256 qam29
14402750000-1.937256 qam30
15410750000-1.538256 qam31
16418750000-1.538256 qam32
17426750000-1.538256 qam33
18434750000-1.238256 qam34
19442750000-1.738256 qam35
20450750000-1.738256 qam36
21458750000-237256 qam37
22466750000-2.438256 qam38
23474750000-238256 qam39
24482750000-2.737256 qam40
1Locked38.600
2Locked38.650
3Locked38.900
4Locked38.660
5Locked37.660
6Locked37.660
7Locked38.650
8Locked38.600
9Locked38.640
10Locked38.900
11Locked37.650
12Locked38.900
13Locked38.650
14Locked37.300
15Locked38.640
16Locked38.660
17Locked38.600
18Locked38.950
19Locked38.660
20Locked38.650
21Locked37.650
22Locked38.660
23Locked38.660
24Locked37.600
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1258000004.675512064 qam6
2394000004.675512064 qam4
3462000004.75512064 qam3
4326000004.625512064 qam5
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA000
0
Speedtest.net and fast.com are very good again. Thank you for the suggestion.
Cheers, Jeremy.
Roger_Gooner
  • 6.41K
  • 468
  • 1.11K
Hero
Message 6 of 8
As your hub looks good I suspect a dodgy connection which can cause a heap of problems.
Andruser
  • 5.54K
  • 971
  • 2.28K
Message 7 of 8
You've got a noisy line that is generating a lot of errors.  Eventually this causes the hub to lose synchronisation on one of more channels and you then get dropped connections, restarts and slowdowns, and that shows in the critical errors in the log and in the massive error count.  You can even see this happening in the first set of downstream data, where the hub has not managed to get a lock on channel 24, which means that channel was either coming back up, or about to go down.
A restart is a temporary fix because that gets the hub to renegotiate all 28 channels from scratch, but because it doesn't solve the underlying noise problem it is likely that the problem will recur in a matter of hours.   Unless there's an area fault, this will require a technician visit to fix, and the most civilised way of getting that is to wait for the forum staff to pick up this thread and advise on next steps, which can be a day or three.`
jezwest
Message 8 of 8
Hello Andruser.
Thank you for your message.
After unscrewing the coax at both ends and screwing it back in again I think it's all good now. The speed is back to maximum again and the errors have gone.
23/06/2020 11:07:36noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 18:02:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Thanks for your help and advice.
Cheers, Jeremy.
