Sign in
Sign out
on 13-04-2022 11:35
Today is the 2nd day using virgin media router.
Yesterday I separated the 2.4 and 5ghz and as a result I was getting pretty much the top speeds upstairs as well
I’ve noticed the speeds have gone to around 200-250. Is the due to trafficking in the network
Ps- I have my own router - ASUS-AX82U WiFi Modem Router
AX 5400.
13-04-2022 11:54 - edited 13-04-2022 11:55
Speed by wifi has range problems and can slow down due to other Wifi AP in your area
BQM, Test for outgoing ports and SSL/L2TP VPN test
on 15-04-2022 12:22
Hi @kebinhedsWelcome to the community!Sorry to hear you have some concerns over your broadband speeds. Are your speed concerns over WiFi only or do you have slower speeds on wired devices also?
Carley - Forum Team
