QAM woes, again.
Icantcrabhere
Superfast
Hi, this may be a somewhat lengthy post,
I'll have to split hub readings from the other day / after a restart today.
The basics out of the way first:
Superhub 3, modem mode. - wired
I have made sure all connections are finger tight.
I have checked both the online fault checker and the phone one
The following first set of logs I post will be from then (Before rebooting the hub).
The other night, 7th July - I noticed a huge latency spike, this turned out to be a Partial service error.
Obviously along with that comes a flood of post-RS errors, as expected.
I am sorry for the formatting on this particular section:
07/07/2022 00:07:15 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2022 00:07:14 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2022 00:07:14 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2022 00:06:16 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2022 00:06:15 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2022 00:05:14 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2022 00:05:14 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2022 00:03:28 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1 Locked 40.3 3057 6731
2 Locked 40.9 1858 7104
3 Locked 40.9 1836 7435
4 Locked 40.9 1828 5666
5 Locked 40.3 1621 5757
6 Locked 40.3 1627 5633
7 Locked 40.3 1811 5775
8 Locked 40.3 1808 5749
9 Locked 40.3 1573 5101
10 Locked 40.3 1876 5284
11 Locked 40.3 1689 5669
12 Locked 40.3 1896 5574
13 Locked 40.3 2822 6718
14 Locked 40.3 1878 6648
15 Locked 40.9 1831 6211
16 Locked 40.3 1893 6552
17 Locked 40.3 2115 6110
18 Locked 38.9 2531 7290
19 Locked 40.3 2399 7146
20 Locked 38.6 3513 7108
21 Locked 38.9 3432 7220
22 Locked 38.9 3493 6851
23 Locked 38.9 3308 6668
24 Locked 38.6 3401 6886
1 ATDMA 0 0 10 0
2 ATDMA 0 0 12 0
3 ATDMA 0 0 6 0
4 ATDMA 0 0 12 0
Even through this, all my upstream QAM were locked to 64,
Until today, that is.
The following posts will show todays logs AFTER a reboot.
41 REPLIES 41
Thank you Matthew,
greatly appreciated 🙂
Hey Icantcrabhere, its no problem at all.
It was my pleasure. Thanks
Matt - Forum Team
New around here?
A small update, a bit of a journal entry if you will.
Regardless of what I say here:
Matthew_ML has been wonderful to work with, i can't give him enough thanks.
Between the start of this thread and the last message in here, it has truly been a nightmare.
Multiple technicians,
many modulation drops and much disappointment(A great book title if you ask me)
We're still no closer in reality to what the route cause of the modulation drops is.
The last technican (Who I actually had to put a complaint in about) had no idea what was causing the issues, so instead has booked a repull for September 15th, however we know how these dates go.
A true shot in the dark, as it were.
Since the tech visited and fidlled with stuff in the cabinet and added attenuators to my line(I have no idea why honestly), the modulation drops have been worse and so has the rate of which PRE-RS errors are rising.
I should have guessed the "work" he'd do would be questionable after the "discussion" with him about a damaged drop cable going into next doors house.
I can elaborate on that further in a different post/PM if needed.
In regards to complaints i have put forward: I have a REF number, but I have no idea how to check up further on that, so maybe someone could help me with this too?
In follow up posts I'll post my current stats from the router log.
1539000000-1.538256 qam17
2547000000-1.738256 qam18
3555000000-1.738256 qam19
4563000000-1.938256 qam20
5571000000-2.238256 qam21
6579000000-2.438256 qam22
7587000000-2.438256 qam23
8595000000-2.238256 qam24
9603000000-2.238256 qam25
10611000000-2.238256 qam26
11619000000-2.538256 qam27
12627000000-2.238256 qam28
13635000000-2.238256 qam29
14643000000-1.938256 qam30
15651000000-1.738256 qam31
16659000000-1.738256 qam32
17667000000-1.738256 qam33
18675000000-1.738256 qam34
19683000000-1.938256 qam35
20691000000-1.738256 qam36
21699000000-1.738256 qam37
22707000000-1.538256 qam38
23715000000-1.738256 qam39
24723000000-238256 qam40
1Locked38.65690
2Locked38.68920
3Locked38.67430
4Locked38.97930
5Locked38.913870
6Locked38.620070
7Locked38.916260
8Locked38.911420
9Locked38.913150
10Locked38.619420
11Locked38.927160
12Locked38.925760
13Locked38.621090
14Locked38.617500
15Locked38.916720
16Locked38.915520
17Locked38.911940
18Locked38.611360
19Locked38.913500
20Locked38.613060
21Locked38.911100
22Locked38.97610
23Locked38.98950
24Locked38.911750
14620000042.5512016 qam1
23260000040.8512016 qam3
32579990740.3512016 qam4
43940000041.2512016 qam2
Sorry for the multiple posts,
Character limits need to be changed for this forum, I swear. aha
27/08/2022 03:37:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2022 22:01:25ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2022 16:05:21criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2022 15:33:9criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2022 15:30:50Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2022 15:30:45criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2022 15:30:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/08/2022 14:34:24criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/08/2022 01:47:34criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/08/2022 01:44:8noticeNOTICE ATOM is restarted due to RPC timeout as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/08/2022 01:39:34criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/08/2022 01:36:38noticeNOTICE ATOM is restarted due to RPC timeout as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/08/2022 01:31:34criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/08/2022 01:29:7noticeNOTICE ATOM is restarted due to RPC timeout as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/08/2022 01:23:34criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/08/2022 01:21:36noticeNOTICE ATOM is restarted due to RPC timeout as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/08/2022 01:15:34criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/08/2022 01:14:6noticeNOTICE ATOM is restarted due to RPC timeout as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
I believe the "NOTICE ATOM" error was during overnight work (since the fault checker showed work due), but I can't be too sure.
Also I can't even use the online fault checker right now, as it seems to be down.
Guess I should rely on the phone one, really!
It's a shame about all these issues, since i've been with VM consistently since 2008~2009ish, and a while before that back in the day.
I've gone from recommending them to actually wanting people to avoid.
now it looks like Hey!Broadband are available in my area.
Hoping more people are going to post reviews + thinkbroadband graphs soon, so i can see how they are locally/generally - honestly looking tempting right now. 😞
Once again adding to my own "Diary" as it were,
need to keep everything logged as best I can.
We were meant to be getting a re-pull,
this was meant to go ahead on the 15th of this month, however two Virgin engineers turned up for it today.
However they were UNABLE to do the job, as the original install, and I quote is "in the top 10 of the worst i've seen"
So they've had to take photos and are going to have to get back to us. - i'm unsure what this entails,
As of now:
My upstream modulation is once again in the gutter:
12360006539512032 qam5
23660000040512032 qam3
34309993240.3512032 qam2
43010027339.5512016 qam4
54959988340.5512064 qam1
having a lovely small burst of packet loss occuring earlier today when the QAM decided to go bad, again:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/2b531bfd99e9c7ef2d5b69ef22112a6703e1f1cc-12-09-2022
From SNR issues, to this,
Over 2 months since this thread started,
Other threads of mine spanning back even longer.
Truly not blessed.
Hey Icantcrabhere, thanks for the posts on our help forum.
We're sorry to see you've had ongoing issues with your services caused by a network fault, have you had a new date confirmed for this re-pull / cabling work yet to complete since you last posted here on Monday?
Please, let us know if you had any updates, glad to assist further if you still need us to.
Adri
They've been and done the repull, i guess.
My power levels are all now out of spec.
14960000049.5512064 qam1
23660000048.8512064 qam3
33010000048.3512064 qam4
44310004049512064 qam2
52360004447.8512064 qam5
1411000000-6.538256 qam1
2419000000-6.738256 qam2
3427000000-738256 qam3
4435000000-7.538256 qam4
5443000000-7.538256 qam5
6451000000-7.738256 qam6
7459000000-7.538256 qam7
8467000000-7.538256 qam8
9475000000-7.738256 qam9
10483000000-7.938256 qam10
11491000000-838256 qam11
12499000000-8.238256 qam12
13507000000-8.438256 qam13
14515000000-8.538256 qam14
15523000000-8.737256 qam15
16531000000-8.937256 qam16
17539000000-937256 qam17
18547000000-9.537256 qam18
19555000000-9.537256 qam19
20563000000-9.737256 qam20
21571000000-1037256 qam21
22579000000-10.237256 qam22
23587000000-10.237256 qam23
24595000000-1037256 qam24
They've driven off already, guessing no consideration to levels after the repull - so i'd assume they're just contractors?
Beyond a joke.
I need this fixed in a timely manner, i am really sick of being messed around.
A same day technician would be wonderful right about now...
Update:
It wasn't even a full repull, just some sort of prep work.
The "2 man repull" isn't due now till October 26th (As I expected)
No real work seemed to have actually been carried out.
and I'm basically being ran in circles trying to get my power levels fixed, after they changed today!
In fact I feel like I'm actively being refused an engineer visit!
I need this escalated - if a VIP or mod can actually help.
This is unacceptable.
I need these levels fixed ASAP.
4435000000-7.438256 qam4
5443000000-7.738256 qam5
10483000000-7.738256 qam10
18547000000-9.437256 qam18
20563000000-9.537256 qam20
14960000049.3512064 qam1
33010001548.3512064 qam4
44309988349512064 qam2
52360013647.8512064 qam5
Looks like they have moved your cable onto a different tap in the cabinet - hence your DS & US levels are wrong.
The US flipping from 64 to 32 or 16 QAM is most likely ingress getting into the cabling, or one or more modems in your area are badly aligned causing upstream issues.
