QAM woes, again.
Icantcrabhere
Superfast
Hi, this may be a somewhat lengthy post,
I'll have to split hub readings from the other day / after a restart today.
The basics out of the way first:
Superhub 3, modem mode. - wired
I have made sure all connections are finger tight.
I have checked both the online fault checker and the phone one
The following first set of logs I post will be from then (Before rebooting the hub).
The other night, 7th July - I noticed a huge latency spike, this turned out to be a Partial service error.
Obviously along with that comes a flood of post-RS errors, as expected.
I am sorry for the formatting on this particular section:
07/07/2022 00:07:15 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2022 00:07:14 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2022 00:07:14 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2022 00:06:16 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2022 00:06:15 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2022 00:05:14 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2022 00:05:14 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2022 00:03:28 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1 Locked 40.3 3057 6731
2 Locked 40.9 1858 7104
3 Locked 40.9 1836 7435
4 Locked 40.9 1828 5666
5 Locked 40.3 1621 5757
6 Locked 40.3 1627 5633
7 Locked 40.3 1811 5775
8 Locked 40.3 1808 5749
9 Locked 40.3 1573 5101
10 Locked 40.3 1876 5284
11 Locked 40.3 1689 5669
12 Locked 40.3 1896 5574
13 Locked 40.3 2822 6718
14 Locked 40.3 1878 6648
15 Locked 40.9 1831 6211
16 Locked 40.3 1893 6552
17 Locked 40.3 2115 6110
18 Locked 38.9 2531 7290
19 Locked 40.3 2399 7146
20 Locked 38.6 3513 7108
21 Locked 38.9 3432 7220
22 Locked 38.9 3493 6851
23 Locked 38.9 3308 6668
24 Locked 38.6 3401 6886
1 ATDMA 0 0 10 0
2 ATDMA 0 0 12 0
3 ATDMA 0 0 6 0
4 ATDMA 0 0 12 0
Even through this, all my upstream QAM were locked to 64,
Until today, that is.
The following posts will show todays logs AFTER a reboot.
41 REPLIES 41
Thank you John,
I appreciate the reply!
I look forward to the update 🙂
Thanks for the help so far,
Jo
You're welcome.
I just want to let you know we are still looking in to this and will update you as soon as possible.
Nat
Thanks Natalie 🙂
fingers crossed for a quick reply from them!
Apologies for the delay in messaging you @Icantcrabhere, we have had no further update from the team so this has been chased for you again today.
Nathan
Thank you, Nathan!
Very much appreciated 🙂
Hi there, any update?
It has been over a week now since the original chase up,
I never seem to have much luck with our AFM. - it's like this every time, kind of unfortunate
Hey there, thanks for reaching out to us.
I've had a look on our end and I cannot see any outages currently as of the moment in the area.
I've checked the service levels and everything is showing up as fine.
May I ask how the service has been recently?
Let us know 🙂
Kind regards.
Ilyas_Y
Well, it was "Ok"
as of this moment however we just had this happen:
(network logs are 1 hour behind, so it's from just moments ago, actually)
01/08/2022 13:30:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/08/2022 13:30:42Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/08/2022 13:30:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/08/2022 13:30:41Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/08/2022 13:30:28Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/08/2022 13:30:24criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/08/2022 13:30:23Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/08/2022 13:30:23criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1Locked38.9336673848
2Locked38.9295435740
3Locked40.3290366728
4Locked40.3317754644
5Locked38.9333714709
6Locked38.9358754899
7Locked38.9323424474
8Locked38.9308636367
9Locked38.9312996253
10Locked38.9335067108
11Locked38.9353846907
12Locked38.6352275806
13Locked38.6356536362
14Locked38.9354436307
15Locked38.6366397499
16Locked38.9357506114
17Locked38.6367686199
18Locked37.6369397146
19Locked38.6366747900
20Locked38.6361059567
21Locked38.6370527066
22Locked38.6365806674
23Locked38.6356885946
24Locked38.6348736007
While this happened, x3 channels dropped from 64QAM > 32 again.
however the channels seem to have (For the moment) returned to 64QAM.
Also the "Pre-RS" count was super low before today, and the "Post-RS" were all at 0.
So there's definitely some sort of SNR/Noise related issue going on here.
There's definitely an issue here and it still isn't being chased up correctly with the AFM.
even after tech visits when everything in my premises is fine.
Please can we get this escalated, I'm losing faith here.
Jo.
Hey Icantcrabhere, thank you for reaching back out with this information.
Okay I would like to take a look in more details and run some tests with you.
Please can you look out for the purple envelope, as I am going to send you a PM. Thanks
Matt - Forum Team
New around here?
Hey Icantcrabhere, thank you for reaching back out I am sorry in the delay in getting back to you, it were my days off.
However I have sent this over to the area field manager and I will reach out once again if I hear anything. Thanks
Matt - Forum Team
New around here?
