coreystol61
Problems with Broadband speed
So I'm signed up to 100mbp/s fibre optic with Virgin.... for the first few months everything was good but for the past month my service has been erratic to say the least. With a wired connection every time I've tested the speed it has been fine, however I can't run a wired connection to my xbox (only wireless) and the problems are unendless I have two channels, a normal one and a 5g one. On the normal one my speed will fluctuate between 5 mbps and 25 mbps. However on the 5g one the speed rarely is above 6mbps. On top of that, ping on the normal channel is between 20 and 110 (literally it bounces up and down whilst gaming) and on the 5g channel I've had ping as high as 1400 (!!) When I run a test on the super hub (diagnostics on the 192 url) it tells me my home network is experiencing a problem and it has a red exclamation mark next to "broadband services", however having been on the phone to Virgin customer support they have told me as my wired connection is fine they are not sending out an engineer and all they can suggest is to "monitor my wireless Internet speeds over the coming weeks" Seeing as Virgin basically didn't help at all I thought I would turn to reddit! Is it possible for me to fix my Internet so I can get back to gaming on my xbox? It literally is unplayable with this wireless and Virgin seem adamant to not do anything. Any advice or help would be so greatfully appreciated! Oh and thanks for reading this!!
Andruser
  • 5.54K
  • 970
  • 2.28K
Re: Problems with Broadband speed
@coreystol61 Is it possible for me to fix my Internet so I can get back to gaming on my xbox?
Setup a BQM.  That'll show what's going on with your VM connection.  Post a link to a live, shared graph here and we'll see what's happening.  Usually needs to run for 24 hours before we can draw reasonable conclusions, but the live graph will continuously update so you can do that immediately.  I'm suspicious that your gaming problems aren't down to speed but poor latency on the cable connection, the BQM will prove or disprove that theory.
