ian_mcgaughrin
Problems with Broadband Speed - Please see stats below
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
659000000
0.2
38
256 qam
32
2
475000000
0.5
40
256 qam
9
3
483000000
0.5
38
256 qam
10
4
491000000
0.4
40
256 qam
11
5
499000000
0.2
40
256 qam
12
6
507000000
0
40
256 qam
13
7
515000000
0
40
256 qam
14
8
523000000
0
38
256 qam
15
9
531000000
0.2
40
256 qam
16
10
539000000
0.2
40
256 qam
17
11
547000000
0
38
256 qam
18
12
555000000
0.2
38
256 qam
19
13
563000000
0.2
38
256 qam
20
14
571000000
0.2
40
256 qam
21
15
579000000
0.2
38
256 qam
22
16
587000000
0
40
256 qam
23
17
595000000
-0.2
38
256 qam
24
18
603000000
-0.5
38
256 qam
25
19
611000000
-0.5
38
256 qam
26
20
619000000
-0.4
38
256 qam
27
21
627000000
-0.2
38
256 qam
28
22
635000000
0
38
256 qam
29
23
643000000
0
40
256 qam
30
24
651000000
0.2
40
256 qam
31
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
60299961
2.425
5120
64 qam
9
2
39399957
2.425
5120
64 qam
12
3
46200034
2.425
5120
64 qam
11
4
53699971
2.425
5120
64 qam
10
Time
Priority
Description
17/08/2020 15:09:20
critical
17/08/2020 15:07:3
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2020 15:05:20
critical
17/08/2020 15:05:3
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2020 14:13:28
critical
17/08/2020 14:13:28
critical
Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2020 14:13:22
critical
17/08/2020 14:13:20
critical
REG RSP not received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2020 14:13:20
Error
T6 Timeout and retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2020 14:13:20
critical
Registration RSP rejected unspecified reason;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2020 14:12:25
critical
17/08/2020 14:12:24
critical
17/08/2020 14:12:24
Error
17/08/2020 14:12:24
critical
01/01/1970 00:00:14
critical
01/01/1970 00:00:12
Warning!
ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:00:7
critical
01/01/1970 00:00:7
Warning!
01/01/1970 00:00:4
critical
01/01/1970 00:00:4
Warning!
Andrew-G
  • 6.06K
  • 1.07K
  • 2.56K
Re: Problems with Broadband Speed - Please see stats below
Your upstream power levels are too low.  I'll flag this for the forum staff.  Usually this is an easy fix for the field technicans.
David_Bn
  • 4.91K
  • 226
  • 401
Thanks for your post on our Community Forums ian_mcgaughrin
I'll seek to have an engineer to come out to your property
Check out the purple envelope in the top right hand corner for my PM, advising you of when they're due to arrive
Kindest regards,
David_Bn
