elJambo
  • 41
Message 1 of 12
Problems since Hub 4
Recently got sent the hub 4. Done the switchover. For the first couple of weeks it worked as expected. Normal speeds (382 down 36 up).
Now I'm getting anywhere from 88 - 210 down and upload speeds have taken around a 50% hit. This is with no changes to current usage.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/956e09581885e582b8076b91aaaabd957959b359
elJambo
  • 41
Message 2 of 12
Re: Problems since Hub 4
253310000001.70000138.605377QAM25625
11390000002.90000238.605377QAM2561
21470000002.59999838.605377QAM2562
31550000002.50000038.983261QAM2563
41630000002.50000038.983261QAM2564
51710000002.20000138.983261QAM2565
61790000002.29999938.983261QAM2566
71870000001.70000138.605377QAM2567
81950000001.70000138.983261QAM2568
92030000002.00000038.983261QAM2569
102110000001.70000138.605377QAM25610
112190000001.90000238.605377QAM25611
122270000001.59999838.605377QAM25612
132350000001.70000138.983261QAM25613
142430000001.70000138.605377QAM25614
152510000002.09999838.605377QAM25615
162590000002.70000138.605377QAM25616
172670000002.00000038.983261QAM25617
182750000001.70000138.983261QAM25618
192830000001.20000138.983261QAM25619
202910000001.09999838.983261QAM25620
212990000000.90000238.983261QAM25621
223070000001.40000238.983261QAM25622
233150000002.29999938.983261QAM25623
243230000002.00000038.605377QAM25624
263710000001.20000138.605377QAM25626
273790000001.50000038.983261QAM25627
283870000000.70000138.605377QAM25628
293950000000.90000238.605377QAM25629
304030000001.09999838.605377QAM25630
314110000001.09999838.605377QAM25631
3.0 Downstream channels
25Locked000
1Locked3115516404141944142
2Locked68231527160131
3Locked6780876081882115
4Locked6768634291036016
5Locked66696341200
6Locked66616571300
7Locked66939077600
8Locked14279881900
9Locked14135058300
10Locked13981675700
11Locked257431521600
12Locked13865878900
13Locked252171472200
14Locked13691873600
15Locked13550565300
16Locked13186455800
17Locked14013645200
18Locked14265537500
19Locked14216617100
20Locked12786112500
21Locked14280651000
22Locked14199881500
23Locked12465067200
24Locked22809743900
26Locked22964829400
27Locked23033239200
28Locked23019695800
29Locked22463043900
30Locked22193258900
31Locked258219886500
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
33804K1560QAM4096424
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
33Locked 1.0857513145219
elJambo
  • 41
Message 3 of 12
Further to the issues. Watching NFL gamepass on a wired Xbox. Never had issues with the service before. Now its dropping bitrate and occasionally buffering.
YouTube sometimes auto selecting lower video quality (480p) on wired devices too, which was the reason that prompted some speed tests in the first place.
elJambo
  • 41
Message 4 of 12
Further investigation on the broadband monitor. 16th October there were to periods of dropped packets. From this point on there seems to be crazy latency spikes. The hub 4 was installed 31st Oct.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 12
Can you please
Copy and paste the contents of the Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again. Use one post for each tab if you wish.
elJambo
  • 41
Message 6 of 12
3.0 Upstream channels
13260000048.0205995120 KSym/sec64QAM9
23940000048.2705995120 KSym/sec64QAM4
34620000048.2705995120 KSym/sec64QAM3
45370000047.5205995120 KSym/sec64QAM2
1US_TYPE_STDMA0010
2US_TYPE_STDMA0010
3US_TYPE_STDMA0010
4US_TYPE_STDMA0010
elJambo
  • 41
Message 7 of 12
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
cmreg-vmdg640-bbt062-b.cm
SFID
629514
Max Traffic Rate
402500089
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
629513
Max Traffic Rate
38500089
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
bestEffort
elJambo
  • 41
Message 8 of 12
Sun 01/11/2020 00:52:134DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 01/11/2020 11:19:583No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 04/11/2020 13:50:334DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 07/11/2020 07:57:116CM-STATUS message sent. Event Type Code: 5; Chan ID: 5; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 08/11/2020 00:53:295Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 08/11/2020 00:53:326CM-STATUS message sent. Event Type Code: 4; Chan ID: 1; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 08/11/2020 01:50:334DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 08/11/2020 04:47:226CM-STATUS message sent. Event Type Code: 5; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 09/11/2020 00:36:345Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 09/11/2020 00:36:536CM-STATUS message sent. Event Type Code: 5; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 09/11/2020 00:58:075Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 09/11/2020 00:58:186CM-STATUS message sent. Event Type Code: 4; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 09/11/2020 00:58:265Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 09/11/2020 00:58:286CM-STATUS message sent. Event Type Code: 5; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 09/11/2020 02:14:475Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 09/11/2020 02:14:496CM-STATUS message sent. Event Type Code: 4; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 09/11/2020 02:15:075Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 09/11/2020 02:15:126CM-STATUS message sent. Event Type Code: 5; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 09/11/2020 12:48:445Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 09/11/2020 12:48:496CM-STATUS message sent. Event Type Code: 5; Chan ID: 7; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 10/11/2020 09:54:005Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 10/11/2020 09:54:296CM-STATUS message sent. Event Type Code: 4; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 10/11/2020 09:54:485Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 10/11/2020 09:54:586CM-STATUS message sent. Event Type Code: 5; Chan ID: 7; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 10/11/2020 11:35:545Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 10/11/2020 11:36:006CM-STATUS message sent. Event Type Code: 5; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 11/11/2020 00:17:555Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 11/11/2020 00:18:216CM-STATUS message sent. Event Type Code: 5; Chan ID: 22; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 11/11/2020 11:03:125Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 11/11/2020 11:03:226CM-STATUS message sent. Event Type Code: 5; Chan ID: 22; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
elJambo
  • 41
Message 9 of 12
Anybody able to help??
92cb01bd50f139fe020dc50090aaa9689cd77fe2-25-11-2020
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 12
What speeds do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
