SKRad
  • 7
Message 1 of 5
Problems in BS11 area
Afternoon,
Just checking if there is any known issue as to why after upgrading to the 350 package, my download is fine (ish), but my upload speed has tanked down to unused levels.
Latency is all over the place, so ranging between 7Mbps and 0.3Mbps (Normally get around 35Mbps consistent)
Area is known for bad line quality but this has only began this evening just as I am trying to run a business christmas campaign and has basically stopped me and my housemate doing our jobs...
Only change to network in last month was introduction to some more beefy gigabit powerline adapters, but have removed these; swapped all cables, factory reset router, and tried directly into wall and still no joy.
Much appreciated!
Tags (1)
SKRad
  • 7
Message 2 of 5
Re: Problems in BS11 area
Cable Modem Status
Item Status Comments
267000000
Locked
Ranged Upstream Channel (Hz)
25797736
Locked
Provisioning State
Online
SKRad
  • 7
Message 3 of 5
1 267000000 9.6 40 256 qam 17
2 275000000 9.5 40 256 qam 18
3 283000000 9.6 40 256 qam 19
4 291000000 9.6 40 256 qam 20
5 299000000 10 38 256 qam 21
6 307000000 10 40 256 qam 22
7 315000000 9.9 40 256 qam 23
8 323000000 9.8 40 256 qam 24
9 331000000 9.5 40 256 qam 25
10 339000000 9.1 40 256 qam 26
11 347000000 8.9 40 256 qam 27
12 355000000 8.9 40 256 qam 28
13 363000000 9 40 256 qam 29
14 371000000 9 40 256 qam 30
15 379000000 8.9 38 256 qam 31
16 387000000 8.8 40 256 qam 32
17 395000000 8.5 40 256 qam 33
18 403000000 8.4 38 256 qam 34
19 411000000 8.3 38 256 qam 35
20 419000000 8.5 40 256 qam 36
21 427000000 8.5 40 256 qam 37
22 435000000 8.5 40 256 qam 38
23 443000000 8.8 38 256 qam 39
24 451000000 8.6 40 256 qam 40
1 Locked 40.3 33 4655
2 Locked 40.3 40 4856
3 Locked 40.3 4002 6276
4 Locked 40.3 3766 6133
5 Locked 38.9 3560 6817
6 Locked 40.9 4103 7243
7 Locked 40.3 4158 7237
8 Locked 40.3 3692 7024
9 Locked 40.3 3144 6865
10 Locked 40.3 2828 6547
11 Locked 40.3 2971 6299
12 Locked 40.3 2956 6370
13 Locked 40.3 3033 6600
14 Locked 40.3 3117 6708
15 Locked 38.9 2920 5555
16 Locked 40.3 3275 7357
17 Locked 40.3 2520 11026
18 Locked 38.9 3423 7558
19 Locked 38.9 3142 7489
20 Locked 40.3 2852 7750
21 Locked 40.3 2959 7915
22 Locked 40.3 2676 10225
23 Locked 38.9 2105 7127
24 Locked 40.3 1752 5199
SKRad
  • 7
Message 4 of 5
1 25797736 40.8 5120 16 qam 12
2 39400025 41 5120 32 qam 9
3 46199858 40.8 5120 64 qam 8
4 32600000 41 5120 64 qam 10
1 ATDMA 0 0 15 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 1 0
4 ATDMA 0 0 0 0
SKRad
  • 7
Message 5 of 5
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt062-b.cm
SFID 2967264
Max Traffic Rate 402500089
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 2967263
Max Traffic Rate 38500089
Min Traffic Rate 0
Max Concatenated Burst 42600
Scheduling Type BestEffort
