WhiteHartMart
  • 129
Message 1 of 11
Problems creeping into my usually stable connection?
Kids have been complaining of gaming connection lately - restarted a broadband monitor and noticed some packet loss occurring quite frequently and on checking my modem stats there seems to be a fair lot of Post RS errors and one upstream channel has dropped to 32qam while the others are still at 64qam?
Can someone take a look please.
14750000003.438256 qam9
24830000003.237256 qam10
34910000003.237256 qam11
4499000000337256 qam12
5507000000337256 qam13
6515000000338256 qam14
7523000000338256 qam15
85310000002.738256 qam16
95390000002.538256 qam17
105470000002.537256 qam18
115550000002.737256 qam19
125630000002.537256 qam20
135710000002.437256 qam21
14579000000237256 qam22
155870000002.237256 qam23
165950000002.237256 qam24
176350000002.737256 qam25
186430000002.738256 qam26
196510000002.737256 qam27
206590000002.737256 qam28
216670000002.937256 qam29
22675000000337256 qam30
23683000000337256 qam31
246910000003.237256 qam32
1Locked38.6859350
2Locked37.61115340
3Locked37.61342410
4Locked37.61679100
5Locked37.61292050
6Locked38.61319860
7Locked38.61296890
8Locked38.91880780
9Locked38.62064080
10Locked37.62506540
11Locked37.62121760
12Locked37.32421180
13Locked37.62694600
14Locked37.33954770
15Locked37.63472030
16Locked37.63873320
17Locked37.3366591412
18Locked38.63270352029
19Locked37.63928593070
20Locked37.641115321130
21Locked37.637127322094
22Locked37.627495921238
23Locked37.62506041376
24Locked37.62592891823
WhiteHartMart
  • 129
Message 2 of 11
Re: Problems creeping into my usually stable connection?
1462001014.225512064 qam1
2326001094.2512064 qam3
3258000064.2512032 qam4
4394000004.2512064 qam2
3ATDMA0000
4ATDMA0000
15/07/2020 12:16:37noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2020 15:49:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2020 00:32:43ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/07/2020 18:28:35ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/07/2020 16:24:6criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/07/2020 00:16:20ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 23:17:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 07:16:36ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 06:51:55ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 06:39:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 05:38:4ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 05:20:20Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/07/2020 05:00:53ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/07/2020 07:28:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/07/2020 04:43:32ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/07/2020 16:43:51ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/07/2020 04:51:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/07/2020 04:44:14ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 05:20:35Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2020 17:23:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 22.33K
  • 2.4K
  • 3.98K
Message 3 of 11
Its not great with those PostRS errors. Can you reboot the hub and heck that the errors have all reset to 0 and then check them every hour or twoe to see if they start reappearing oover a short timescale - they shouldnt.
Also if you havent got one, can you set up a free “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” when you have the first 24h period.
WhiteHartMart
  • 129
Message 4 of 11
Thanks - already had a monitor up and running so here it is:-
My Broadband Ping - Virgin 500
  • 22.33K
  • 2.4K
  • 3.98K
Message 5 of 11
Mmmm looks fine.. except between 4-9pm - packet loss evidence. Is that a one off or a regular event?
May be related to congestion in your location. See if the postRS errors are reappearing.
WhiteHartMart
  • 129
Message 6 of 11
Thanks - I stopped using the Broadband Monitor after some issues were fixed almost a year ago so can't comment on frequency of packet loss - will definitely keep an eye on it though and reset the Hub in a bit to check those Post errors.  Thanks.
  • 22.33K
  • 2.4K
  • 3.98K
Message 7 of 11
Might be a connection issue of course - but you haven't actually said - are the kids gaming devices connected on ethernet cables or wifi when they get the problems?
Do other non-gaming devices have issues at the same time as the gamers?
And what are their issues exactly - are they being cut off or is it lagging, or what ?
WhiteHartMart
  • 129
Message 8 of 11
Lagging and fairly frequent disconnects - they are both connected with Homeplugs and not Wifi. Then again, their problems could be game server related, it's just when I saw those Hub errors and the Upstream Qam had dropped, i though I would check here.
Anonymous
Not applicable
Message 9 of 11
One of the 4 upstream channels is at 32 qam when it should be 64 qam, which could be related to your issues.
WhiteHartMart
  • 129
Message 10 of 11
Things seem to be getting worse today
