Problem: My Upload Speed M500 VOLT Cap reduced from 52 to 36
Mattseyboy
Dialled in
I upgraded my package to VOLT M500 back on July 7th as Upload Speed is important to me as we have multiple connections one of which my daughter uses for Streaming games etc to viewers in Highest Quality.
The M500 service provided stable Upload speeds all of which when tested every couple of days were between 47-52 Mbps without fail in between 08/07/23-08/08/23.
From 08/08/23 following VM completing "essential maintenance work in my area" (I was notified by text message of these works hence how I know) the Upload Speed has dropped down to a cap of 36.6 Mbps both wired and on wi-fi each and every time I run a Speed Test (Ookla). It effectively now seems to be capped at the advertised Upload Speed for the M350 package since these works were undertaken whilst my Download speeds are still within the acceptable range associated for M500.
There is no Upload Speed guarantee offered by VM which CS confirmed to me and I accept BUT why would my Upload Speed now be capped at the wrong band after having been correct for 30 days up until the exact same day the works were completed?
I can only assume that the VM Network settings are now wrongly set up for my household/area as a result of these maintenance works however CS are unable to offer any real assistance other than confirm they ran a check and I'm getting 37 Mbps, which I already know, and to remind me there are no Upload Speed minimum guarantees.
I've done several re-boots and pin hole resets of the router but still only 36Mbps on every test, the reading rockets up to that speed and then stays there until the test is complete both wired and via wi-fi so I baffled by this one?
30 REPLIES 30
Mattseyboy
Dialled in
I have just noticed whilst looking on my Think Broadband profile that my Host IP Address changed at around 9.45am on 08/08/2023 also so wonder if that has had anything to do with the change in my upload speed cap, not exactly what I envisaged when I was told that essential maintenance works were being undertaken in my area to improve my service.
Check the configuration page in your router status
I'm honestly not sure what any of this means but I've got this info to offer:
330750000
Locked
Ranged Upstream Channel (Hz)
49600000
Locked
Provisioning State
Online
1330750000038256 qam25
22027500002.240256 qam9
3210750000238256 qam10
42187500001.540256 qam11
52267500001.440256 qam12
62347500001.238256 qam13
72427500001.240256 qam14
82507500001.240256 qam15
92587500000.740256 qam16
102667500000.538256 qam17
112747500000.238256 qam18
122827500000.540256 qam19
132907500000.540256 qam20
142987500000.538256 qam21
153067500000.240256 qam22
163147500000.238256 qam23
17322750000038256 qam24
18338750000-0.438256 qam26
19346750000-0.538256 qam27
20354750000-0.938256 qam28
21362750000-1.538256 qam29
22370750000-238256 qam30
23378750000-2.238256 qam31
24386750000-2.238256 qam32
1Locked38.9950
2Locked40.9353250
3Locked38.910131100
4Locked40.986626990
5Locked40.98339040
6Locked38.97850
7Locked40.31830
8Locked40.31790
9Locked40.92020
10Locked38.92550
11Locked38.92140
12Locked40.32140
13Locked40.31920
14Locked38.62830
15Locked40.32920
16Locked38.63800
17Locked38.93180
18Locked38.94020
19Locked38.94420
20Locked38.64360
21Locked38.95960
22Locked38.68930
23Locked38.6100674
24Locked38.695145
14960000045.3512064 qam1
22360000042.3512064 qam5
33010000044.3512064 qam4
43660000043.8512064 qam3
54310000045.3512064 qam2
1ATDMA0080
2ATDMA0050
3ATDMA0080
4ATDMA0050
5ATDMA0070
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
fd;kfoA,.iyewrkldJKDHSUBsgvca
SFID464
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID463
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
26/09/2023 17:07:1noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/09/2023 12:17:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/09/2023 06:03:6noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/09/2023 06:03:6ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2023 23:56:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2023 18:03:6noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2023 18:03:6ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/09/2023 17:43:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/09/2023 06:03:6noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/09/2023 06:03:6ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/09/2023 17:09:17criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2023 18:03:6noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2023 18:03:6ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/09/2023 06:29:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/09/2023 06:03:5noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/09/2023 06:03:5ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/09/2023 21:35:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/09/2023 18:03:5noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/09/2023 18:03:5ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/09/2023 10:54:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Cardiffman282
Super solver
Yup upstream has been capped at 38520000.
Cancel VM here
Complain to VM
here
Demand compensation from VM here
Demand your call recordings here
Monitor the state of your VM connection here
Thanks for confirming my thoughts, could someone at VM please re-instigate the original Cap that I clearly had applied and was receiving for the first month of my new contract between 08/07/23 to 08/08/23 when I was receiving 47-52 Mbps until the essential maintenance works in my area to improve my service seemingly altered my settings and lowered my cap having the opposite effect?
Hey Mattseyboy,
Welcome back to the community and thanks for taking the time to post.
I’m sorry to hear of the issues that you’re having with your connection, we do not cap any connection speeds. I have looked into your account and cannot see any issues at the moment.
Has anything changed with your connection since you last posted?
Kind Regards,
Steven_L
Hi Steven_L
I've just tested it again and it's still 36.8 Mbps Upload, the issue is that from 08/07/23-08/08/23 I was receiving Upload speeds of 47-52 Mbs everytime I tested then ever since essential maintenance works were undertaken in my area to improve my service on 08/08/23 I am only able to obtain 36.6-36.8 Mbps every single time on both wired (direct to the Hub3)  and over wi-fi connections.  In my opinion something has detrimentally changed as a result of the engineering works, clearly it can't be a coincidence that every test I've run since being informed the works were complete i'm now limited to the Upload speeds associated with the M350 service rather than the M500 which I deliberately upgraded too on 08/07/23 in order to get the higher Upload speed .  It's not like I've never been able to achieve the Upload speeds advertised but just that since the maintenance works it's now impossible to get an upload speed in excess of 37 Mbps.
It was suggested above from my Max Traffic Rate (see below) that that was the cause but sadly i'm no expert, would you be able to look at what was changed during the maintenance and see if whatever has gone wrong can be rectified in order to re-enable my original Upload Speed or has the local equipment been downgraded and its no longer capable of supplying the speeds it did prior to 08/08/23, ie: is it something to do with the Docsis Mode?
Bit of a brain scratcher really as to what has gone wrong since 08/08/23?
SFID463
Min Traffic Rate0
