TheBlobfulOne
  • 10
Message 1 of 19
Pretty Slow WiFi
For the last 3 days or something, the internet around the house has been pretty bad. We bought a new box (Hub 3.0) last week, so I'm sure that isn't the problem. I followed all the steps the Virgin Media website gave for trying to fix this problem, but to no avail. For reference, I use wired ad get around 160 mbps tops, but the last 3 days have been lower than 20 mbps, going above once every few hours or so to about 70 for a few seconds. Any ideas?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 19
Re: Pretty Slow WiFi
What is your contracted speed ?
What speed do you get at >> speedtest.net << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
TheBlobfulOne
  • 10
Message 3 of 19
So after testing, with a Cat 5e cable with my router on router mode I peaked at around 70 mbps with no other devices connected, sometimes dipping below 50, though I was contracted 200 mbps.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 19
Can you Login to the Hub Settings and navigate to the Connected Devices page - what does it report the 'connection speed as for the cable connected device you used for the speed test?
TheBlobfulOne
  • 10
Message 5 of 19
It says 100 mbps
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 19
OK, thanks.
That tells us that the capability of the cable or the Network Interface Card (NIC) in the computer is not able to carry a signal more than 100Mbs.
What is the make and model of the device you are using to test with ?
What is the Operating System (OS) ?
Have you got another ethernet cable you can connect with and give it another try ?
TheBlobfulOne
  • 10
Message 7 of 19
Normally this problem could've been fixed, but the odd part is that I've reached speeds of around 160 mbps on my laptop with a cable, even with 5-7+ other devices connected, which is why I'm confused. Trying with other cables didn't change anything, my OS version is 19041.572 and I'm using an HP Pavillion Notebook. Thanks for all your help so far.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 19
Go into your Device Manager and check for a driver update for the NIC, Windows updates can throw all sorts of wobblies into the OS.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 19
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
TheBlobfulOne
  • 10
Message 10 of 19
All of the above is OK, but before moving on, how safe is it to post my BQM?
