kschawla
Message 1 of 8
Powerline adapters and ethernet cable type compatible with Hub 3.0
Now that I have got Virgin's 100Mbps internet (Hub 3.0 router),  I am looking to enhance the connectivity around the house (mainly upstairs where the internet is a bit weak when I am on zoom calls).
I found that powerline ethernet adapters are a good solution. I don't want too many cables and holes around the house. Could someone please recommend/suggest what shall I go for, (compatible with Virgin Media's Hub 3.0)
  1. Ethernet cables For e.g. Cat 8 or 7
  2. Powerline adapters  - which make and models?
K
Richw1982
  • 503
  • 34
  • 120
Rising star
Message 2 of 8
Re: Powerline adapters and ethernet cable type compatible with Hub 3.0
The TP-Link Deco range are quite a good low price mesh system
I work for VMO2 but all opinions are my own and are based on my own experiences
kschawla
Message 3 of 8
Thank you for your quick response. If I go ahead with Cat 8 cables is that ok?
  • 29.04K
  • 2.89K
  • 5.47K
Message 4 of 8
Cat8 cables are overkill. Cat6 will be cheaper and jut as good on the 100mbps package.
But what do you actually want upstairs? Improved wifi ? Ethernet connectivity ? Both?
kschawla
Message 5 of 8
Thanks John, It will be both ethernet and wifi. For multiple devices.
conman33158
  • 1.67K
  • 134
  • 364
Super solver
Message 6 of 8
I've used the Devolo powerline adapters in the past which are pretty good, as for Ethernet cables Cat 5e would suffice and is good up to 1gb 🙂
BT Full Fibre 900 FTTP - Asus RT-AX82U to Openreach ONT Box & Asus RT-AX56U with AiMesh setup
  • 29.04K
  • 2.89K
  • 5.47K
Message 7 of 8
A few comments about powerline's from an older post of mine are below. The Devolo ones are probably the "best" ones you can get but do tend to be expensive - for the same money you could get a good mesh system. Other powerlnes for less £ than the Devolo's may wll suffice.
Have a search and see what best matches your needs.
_________________________________________________________________
You need 2 powerline adapters.  One connected to the Hub by short cable and the other in the room connected to the devices by short cable(s).  Use Cat6a ethernet cables to do the connections.
Get ones with 2 ethernet ports and you can plug a Wireless Access Point into one port - or get powerlines with built in wifi - but check the specs. I would also get the highest rated "speeds" you can afford.  Netgear do an AC2000 one as well as an AC1200 or 1000 - which should be good enough (mine are 1200's).  Also, "passthrough" power sockets are very useful to have.  Also decide whether you want the ethernet port(s) on the top or bottom of the units (they supply both) so you dont get stymied by skirting boards etc.
Note - dont plug them into extension cable boxes as that stuffs them (hence passthrough" is good) and your electrical circuits must at least go through the same consumer unit (fuse box) - noise on the circuitry can also be a problem but you wont know that until you try them - or have the circuit(s) tested.
kschawla
Message 8 of 8
Thank you all for your great, quick response. 🙂
