Frank029
  • 21
Message 1 of 47
Power levels
Can the team have a look at my speed as it slows down and have had a few random drop outs during the day and night. Power levels seem to drop on the downstream and increase on the upstream during a 24 hour period.
1474250000-3.738256 qam9
2410250000-3.238256 qam1
3418250000-3.538256 qam2
4426250000-3.438256 qam3
5434250000-3.538256 qam4
6442250000-2.938256 qam5
7450250000-2.938256 qam6
8458250000-338256 qam7
9466250000-3.238256 qam8
10482250000-438256 qam10
11490250000-4.537256 qam11
12498250000-4.538256 qam12
13506250000-537256 qam13
14514250000-537256 qam14
15522250000-5.437256 qam15
16530250000-5.737256 qam16
17538250000-5.937256 qam17
18546250000-5.737256 qam18
19554250000-5.737256 qam19
20562250000-5.537256 qam20
21570250000-5.737256 qam21
22578250000-5.437256 qam22
23586250000-5.437256 qam23
24594250000-5.537256 qam24
1Locked38.6520
2Locked38.92734
3Locked38.6640
4Locked38.6370
5Locked38.61020
6Locked38.6170
7Locked38.6280
8Locked38.6250
9Locked38.9420
10Locked38.6370
11Locked37.6520
12Locked38.6910
13Locked37.3680
14Locked37.6970
15Locked37.34250
16Locked37.61110
17Locked37.61670
18Locked37.61340
19Locked37.6840
20Locked37.6990
21Locked37.6930
22Locked37.61370
23Locked37.6450
24Locked37.6230
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
15370000050.8512064 qam6
23940000050512064 qam8
34620000050.5512064 qam7
46030000051512064 qam5
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
Frank029
  • 21
Message 2 of 47
Re: Power levels
19/04/2021 15:59:4ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/04/2021 05:53:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/04/2021 20:47:32ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/04/2021 20:47:30ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2021 09:42:32noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/04/2021 21:09:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2021 23:37:42ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/04/2021 22:59:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/04/2021 12:24:44ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/04/2021 20:23:42noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/04/2021 16:04:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/04/2021 21:50:38ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/03/2021 00:09:26criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/03/2021 19:41:47noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/03/2021 15:22:50ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/03/2021 19:09:58criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/03/2021 23:14:58ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/03/2021 23:14:56ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Andrew-G
  • 9.5K
  • 1.53K
  • 4.52K
Message 3 of 47
Re: Power levels
You're right to be suspicious, your downstream power levels are too low on many channels, and the upstream is too high.  Usually that's a simple fix for a technician, and I've flagged for staff to advise, and they'll book a technician for you if that's appropriate.
Jodi_S
  • 3.23K
  • 164
  • 338
Message 4 of 47
Re: Power levels
Hi Frank029,
Welcome to our community and thanks for posting. Really sorry to hear that you're having problems with our internet services, with the random drop out and speed issues.
Remotely looking from our end we have located your account, from the details you have provided from your community profile and have done further checks for you. We can see that there is a power level issue and we would indeed need a technician to come and resolve this for you.
I have booked a technicians visit in which you can check the date and time here.
Kind regards Jodi.
Frank029
  • 21
Message 5 of 47
Re: Power levels
Many thanks.
Steven_L
  • 7.82K
  • 482
  • 791
Message 6 of 47
Re: Power levels
Thanks for your reply @Frank029
Please keep us updated and let us know how the visit goes.
Steven_L
Frank029
  • 21
Message 7 of 47
Re: Power levels
Had the technician visit did a few things in the box down the road, and says the levels are in range.
downstream bonded channels
1474250000-3.538256 qam9
3418250000-3.438256 qam2
4426250000-3.238256 qam3
5434250000-3.238256 qam4
6442250000-2.738256 qam5
7450250000-2.738256 qam6
8458250000-2.738256 qam7
11490250000-4.538256 qam11
17538250000-637256 qam17
22578250000-5.237256 qam22
23586250000-5.237256 qam23
1Locked38.9230
2Locked38.91660
3Locked38.6660
4Locked38.9490
5Locked38.6530
6Locked38.9200
7Locked38.6200
8Locked38.9170
9Locked38.6110
10Locked38.9130
11Locked38.6240
12Locked38.9350
13Locked37.6260
14Locked37.6400
15Locked37.61690
16Locked37.6510
17Locked37.3710
18Locked37.6490
19Locked37.6280
20Locked37.6350
21Locked37.6390
22Locked37.6840
23Locked37.6680
24Locked37.6300
Frank029
  • 21
Message 8 of 47
Re: Power levels
23939995150512064 qam8
46030000551512064 qam5
1ATDMA0010
3ATDMA0000
4ATDMA0000
Steven_L
  • 7.82K
  • 482
  • 791
Message 9 of 47
Re: Power levels
Thanks for coming back to us @Frank029
I can see no issues on your account from our side and the engineer noted that you're getting full speeds, is that correct?
Regards,
Steven_L
Frank029
  • 21
Message 10 of 47
Re: Power levels
All seems well at the moment i will just keep an eye on it for now.
