Hi all
Hopefully the images are presenting below. As you can see from the screenshots, it all doesn’t look right, my setup is Ultimate Oomph, I have 1 Superhub 3 and 2 V6 boxes.
To achieve this the installer ran the main cable up to my first floor bedroom, through there into the second bedroom where the main wire enters into a technetics non-powered splitter and one branches off to the V6 in that room then the other branches off to outside the rear of the property and down to the living room below where the cable then enters into a powered HDU-200 and splits off to my second V6 and my Superhub 3.
Was there a better way of setting this up or is it pretty standard? Reason for all the info was incase that’s why my power levels are low and maybe there’s too much cable?
1 | 139000000 | -7.7 | 35 | 256 qam | 1 |
2 | 147000000 | -8.2 | 33 | 256 qam | 2 |
3 | 155000000 | -8 | 34 | 256 qam | 3 |
4 | 163000000 | -6.9 | 36 | 256 qam | 4 |
5 | 171000000 | -6.9 | 36 | 256 qam | 5 |
6 | 179000000 | -7 | 36 | 256 qam | 6 |
7 | 187000000 | -6.7 | 36 | 256 qam | 7 |
8 | 195000000 | -7 | 36 | 256 qam | 8 |
9 | 203000000 | -7.2 | 36 | 256 qam | 9 |
10 | 211000000 | -7.2 | 37 | 256 qam | 10 |
11 | 219000000 | -7.7 | 31 | 256 qam | 11 |
12 | 227000000 | -7.7 | 30 | 256 qam | 12 |
13 | 235000000 | -7.5 | 36 | 256 qam | 13 |
14 | 243000000 | -7.4 | 36 | 256 qam | 14 |
15 | 251000000 | -7.5 | 36 | 256 qam | 15 |
16 | 259000000 | -7.2 | 36 | 256 qam | 16 |
17 | 267000000 | -7.5 | 36 | 256 qam | 17 |
18 | 275000000 | -7.7 | 36 | 256 qam | 18 |
19 | 283000000 | -7.5 | 36 | 256 qam | 19 |
20 | 291000000 | -8 | 36 | 256 qam | 20 |
21 | 299000000 | -8.5 | 35 | 256 qam | 21 |
22 | 307000000 | -9 | 35 | 256 qam | 22 |
23 | 315000000 | -8.9 | 35 | 256 qam | 23 |
24 | 323000000 | -8.5 | 36 | 256 qam | 24 |
1 | Locked | 35 | 183151 | 1563 | |
2 | Locked | 33.8 | 1033137 | 1470 | |
3 | Locked | 34.2 | 1079259 | 717592 | |
4 | Locked | 36.6 | 215751 | 570 | |
5 | Locked | 36.3 | 32007 | 712 | |
6 | Locked | 36.3 | 2089 | 628 | |
7 | Locked | 36.6 | 1407 | 1863 | |
8 | Locked | 36.6 | 677 | 423 | |
9 | Locked | 36.6 | 893 | 250 | |
10 | Locked | 37.3 | 1129 | 361 | |
11 | Locked | 31.7 | 7163180 | 25164 | |
12 | Locked | 30.5 | 73819070 | 40462 | |
13 | Locked | 36.6 | 537 | 314 | |
14 | Locked | 36.6 | 711 | 237 | |
15 | Locked | 36.6 | 727 | 252 | |
16 | Locked | 36.3 | 688 | 464 | |
17 | Locked | 36.6 | 502 | 303 | |
18 | Locked | 36.6 | 609 | 292 | |
19 | Locked | 36.3 | 370 | 181 | |
20 | Locked | 36.6 | 536 | 189 | |
21 | Locked | 35.7 | 891 | 297 | |
22 | Locked | 35.5 | 754 | 227 | |
23 | Locked | 35.7 | 355 | 224 | |
24 | Locked | 36.3 | 214 | 307 | |
