ilambie
  • 20
Message 1 of 22
Post upgrade speed slow down
Having recently upgraded from 200mb to 500mb and changing to the Hub 3 ive dropped from 200mb+ to less than 2mb, sometimes as low as 0.02MB. That's both via wifi and LAN.
I've tried many re-boots as per other threads, i've spoken to the tech team who have re-sent settings to my router after doing remote checks on my new router and still no joy at all.
I've checked and re-checked all connections are sound and at least finger tight.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 22
Re: Post upgrade speed slow down
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 22
Can you please
ilambie
  • 20
Message 4 of 22
ilambie
  • 20
Message 5 of 22
13310000006.538256 qam25
22510000007.838256 qam15
32590000007.940256 qam16
42670000007.640256 qam17
52750000007.440256 qam18
6283000000738256 qam19
7291000000738256 qam20
82990000006.838256 qam21
93070000006.538256 qam22
103150000006.538256 qam23
113230000006.538256 qam24
123390000006.438256 qam26
133470000006.438256 qam27
14355000000638256 qam28
153630000005.638256 qam29
163710000005.638256 qam30
173790000005.538256 qam31
183870000005.538256 qam32
193950000005.538256 qam33
204030000005.438256 qam34
214110000005.338256 qam35
22419000000538256 qam36
23427000000538256 qam37
24435000000538256 qam38
1Locked38.960
2Locked38.940
3Locked40.350
4Locked40.350
5Locked40.340
6Locked38.640
7Locked38.940
8Locked38.950
9Locked38.950
10Locked38.950
11Locked38.950
12Locked38.650
13Locked38.960
14Locked38.960
15Locked38.960
16Locked38.950
17Locked38.6110
18Locked38.960
19Locked38.960
20Locked38.680
21Locked38.650
22Locked38.950
23Locked38.970
24Locked38.900
ilambie
  • 20
Message 6 of 22
16030000240.5512064 qam9
23940000039512064 qam12
34620000039512064 qam11
45370000040.5512064 qam10
3ATDMA0000
4ATDMA0000
ilambie
  • 20
Message 7 of 22
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
7dsfd;kfoA,.iyewrkldJKDHS
SFID17154
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID17153
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
ilambie
  • 20
Message 8 of 22
01/01/1970 02:42:11ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 02:41:28noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 02:41:4Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 01:23:45ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 01:23:38noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 01:12:4ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 01:08:46noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 01:08:35ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 01:08:16noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 01:07:55ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 01:07:22Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:00:25ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:55Warning!ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:00:23ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:02:30Warning!ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:00:18ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:02:22Warning!ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:00:21ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:50Warning!ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:15:0ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 22
Your >> BQM << needs time to develop.
The Hub data all looks OK.
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
ilambie
  • 20
Message 10 of 22
Via Cat 5e on my laptop and the same on my phone via wifi
