HGP
  • 23
Message 11 of 18
Re: Post RS errors intermittently slow speeds
Just turned the hub off for 5 minutes as advised. This has cleared the post RS errors and updated the SNR that was at 38 instead of 40.
The issues seems most prevalent in the evening around 9-11pm so I will see how it is this evening then come back to you.
Not been able to test wired connection yet as my partner is still unwell to use his work computer
https://www.thinkbroadband.com/broadband/monitoring/quality/share/1d297b0ebcccf3e65c1418080b18a1022a870525
HGP
  • 23
Message 12 of 18
After 3 hours Post RS error on channel 7 downstream and upstream channel 3 has dropped to 16 QAM modulation (this has been an issue since first got router, it is more often on 16 than 64). Usually get timeout errors on this channel too.
ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
13940000047.5512064 qam2
24620000047.8512064 qam1
33260000047.5512016 qam3
42579997947.5512064 qam4
ChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 TimeoutsT4 Timeouts
3ATDMA0000
4ATDMA0000
HGP
  • 23
Message 13 of 18
12590000003.240256 qam16
22510000003.240256 qam15
3267000000340256 qam17
42750000003.540256 qam18
52830000004.540256 qam19
62910000004.640256 qam20
7299000000540256 qam21
83070000004.640256 qam22
93150000004.840256 qam23
103230000004.940256 qam24
113310000004.840256 qam25
12339000000540256 qam26
133470000005.140256 qam27
143550000005.140256 qam28
153630000005.340256 qam29
163710000004.840256 qam30
173790000004.840256 qam31
183870000004.840256 qam32
193950000004.640256 qam33
204030000004.640256 qam34
21411000000440256 qam35
224190000003.740256 qam36
235230000005.540256 qam37
245310000005.540256 qam38
1Locked40.3550
2Locked40.3470
3Locked40.3420
4Locked40.3270
5Locked40.9340
6Locked40.3260
7Locked40.33611
8Locked40.3280
9Locked40.3310
10Locked40.3460
11Locked40.3270
12Locked40.9400
13Locked40.3320
14Locked40.3370
15Locked40.9360
16Locked40.3370
17Locked40.3380
18Locked40.9360
19Locked40.9340
20Locked40.3410
21Locked40.3430
22Locked40.9230
23Locked40.3470
24Locked40.3430
HGP
  • 23
Message 14 of 18
Issues still today, 3 of the SNR dropped from 40 to 38, should this happen?
12590000002.740256 qam16
22510000002.740256 qam15
32670000002.438256 qam17
4275000000338256 qam18
52830000003.940256 qam19
6291000000440256 qam20
72990000004.540256 qam21
83070000004.140256 qam22
93150000004.140256 qam23
103230000004.340256 qam24
113310000004.340256 qam25
123390000004.440256 qam26
133470000004.540256 qam27
143550000004.540256 qam28
153630000004.540256 qam29
163710000004.140256 qam30
173790000004.140256 qam31
183870000004.140256 qam32
193950000004.140256 qam33
20403000000440256 qam34
214110000003.538256 qam35
224190000003.240256 qam36
23523000000540256 qam37
24531000000540256 qam38
HGP
  • 23
Message 15 of 18
upstream the modulation that drops has gone back to 64 but got anot6T3 timeout
13940014147.5512064 qam2
24620000047.5512064 qam1
33259998147.5512064 qam3
42579991747.5512064 qam4
3ATDMA0010
4ATDMA0010
HGP
  • 23
Message 16 of 18
@David_Bn yes issues with multiple devices and wired connection.
HGP
  • 23
Message 17 of 18
But very intermittent. After posting ethernet speed of 14.31 via ethernet. I ran WiFi again and it it was 113.52 then re did ethernet and it got 44.92 (all averages)
Akua_A
  • 3.72K
  • 92
  • 249
Message 18 of 18
Thank you for your response @HGP
I have had a look into your hub data and service backend and everything appears fine. How is service today? Is there any improvement?
Akua_A
