Post RS errors et al...
Hello all,
I have recently upgraded to M350 fibre broadband and as part of this upgrade was sent a new Hub3 to replace my old Hub2.
Whilst the broadband speed is very good, I have noticed a few glitches that seemed to affect online gaming more than anything - this is something that we never experienced prior to the upgrade.
Anyway, I have done a little trawling through these community pages and seem to have some similar issues to others in regard to Post RS errors and some spurious entries in the network log. See below.
For note, I have rebooted the Hub several times and each time, the errors are reset to zero before they build up over the period of around a week. The errors listed below are probably over the last 2 weeks or so.
Given the current pandemic we are all going through, I'm not expecting a visit from an engineer any time soon but if anyone has any other suggestions, then please let me know.
Carl.
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
14830000004.538256 qam30
21870000006.540256 qam7
31950000006.440256 qam8
42030000006.140256 qam9
5211000000640256 qam10
6219000000640256 qam11
7227000000640256 qam12
82350000005.940256 qam13
92430000005.640256 qam14
102510000005.640256 qam15
112590000005.640256 qam16
122670000005.840256 qam17
132750000005.540256 qam18
142830000005.640256 qam19
152910000005.638256 qam20
16299000000638256 qam21
173070000006.140256 qam22
183150000006.340256 qam23
19323000000640256 qam24
20443000000540256 qam25
214510000004.640256 qam26
224590000004.638256 qam27
234670000004.538256 qam28
244750000004.538256 qam29
1Locked38.91105978
2Locked40.916827710812
3Locked40.31517627892
4Locked40.91275036305
5Locked40.3990564640
6Locked40.3743983666
7Locked40.3655313362
8Locked40.3555823350
9Locked40.3463982906
10Locked40.3385012804
11Locked40.3359492889
12Locked40.3334192473
13Locked38.9300722734
14Locked40.3238702794
15Locked38.9186822925
16Locked38.9134962072
17Locked40.397742286
18Locked40.374621879
19Locked40.362711706
20Locked40.315321239
21Locked40.313851256
22Locked38.912931426
23Locked38.91150960
24Locked38.911341173
09/04/2020 14:00:36noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/04/2020 11:29:2ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/04/2020 03:45:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/04/2020 21:23:55noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/04/2020 21:23:55ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/04/2020 11:33:14ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/04/2020 03:26:18Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/04/2020 01:42:37ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2020 09:09:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2020 01:31:24noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2020 01:31:24ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/03/2020 09:46:21ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/03/2020 22:15:55criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/03/2020 18:01:21ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/03/2020 18:45:12criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/03/2020 13:24:5Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/03/2020 02:48:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/03/2020 09:43:53Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/03/2020 18:56:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/03/2020 12:16:4Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 4.66K
  • 854
  • 1.23K
Re: Post RS errors et al...
Hello
As quite clearly shows these this could be down to noise on the line, go around and check that all coaxial connections to all VM equipment are finger tight and that there are no unterminated connections, once done power off the hub for 30 secs, and back on if the Post RS errors keep increasing at that rate you will need an engineer to resolve.
Regards Mike
Hi Mike,
Thank you for your quick response.
As suggested, I have rechecked the coax connections and all appear to be ok and tight.
Yesterday morning, I reset my router so the error counts would reset to zero. The latest logs are shown below.
I am concerned about the 'critical' and 'warning' error messages that are regularly appearing in the Network Log. Is this normal? or to be expected with the amount of errors I seem to be getting?
Thanks in advance.
16/04/2020 13:03:59noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2020 15:09:1criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2020 11:11:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2020 09:24:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2020 08:35:6noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/04/2020 22:25:56ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/04/2020 01:20:55criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2020 17:30:30noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2020 17:30:30ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2020 13:45:17ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2020 11:33:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2020 11:03:35Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2020 02:29:45ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14830000003.538256 qam30
21870000005.140256 qam7
3195000000540256 qam8
42030000004.840256 qam9
52110000004.640256 qam10
62190000004.840256 qam11
72270000004.638256 qam12
82350000004.540256 qam13
92430000004.440256 qam14
102510000004.440256 qam15
112590000004.440256 qam16
122670000004.540256 qam17
132750000004.340256 qam18
142830000004.540256 qam19
152910000004.438256 qam20
162990000004.838256 qam21
17307000000540256 qam22
18315000000540256 qam23
193230000004.840256 qam24
20443000000438256 qam25
214510000003.740256 qam26
224590000003.538256 qam27
234670000003.538256 qam28
244750000003.538256 qam29
1Locked38.69262
2Locked40.317680615
3Locked40.917034520
4Locked40.314940354
5Locked40.311856231
6Locked40.38164279
7Locked38.96788166
8Locked40.35790160
9Locked40.34879176
10Locked40.33862115
11Locked40.33779162
12Locked40.3350560
13Locked40.32922183
14Locked40.92290135
15Locked38.91713145
16Locked38.9121093
17Locked40.3798297
18Locked40.355365
19Locked40.342190
20Locked38.911942
21Locked40.312458
22Locked38.610965
23Locked38.98455
24Locked38.995120
