Originlabs
  • 5
Message 1 of 13
Post RS Errors + Packet Loss
I've recently started experiencing intermittent connection issues, where the upload speed will almost halt (at 0.01Mbps), and basic ping test will show 20-40% packet loss.  This normally occurs for up to 30 minutes, but last month became continuous and made the connection unusable.
An engineer did visit last month, and replaced all the connections on the wall outside the property, and fitted a new connection point inside.  This seemed to resolve the issue for a while, but it's now started occurring again.
Looking at the modulation of the upstream channels, this has dropped from 64qam down to 32/16qam over the past week.
UpstreamUpstream
DownstreamDownstream
Downstream ErrorsDownstream Errors
DJ_Shadow1966
  • 6.88K
  • 1.32K
  • 1.9K
Message 2 of 13
Re: Post RS Errors + Packet Loss
Hello
Your upstream power levels are right on the maximum, you are going to need an engineer to resolve that.
Regards Mike
Zak_M
  • 3.55K
  • 226
  • 354
Message 3 of 13
Good afternoon,
A very warm welcome to the forums and thank you for taking the time to reach out to us.
Apologies for the delay in response.
How are things looking since your first reached out?
Kind regards,
Zak_M
Originlabs
  • 5
Message 4 of 13
Hi Zak,
Unfortunately the upload speed hasn't gotten any better (if anything its getting worse), to the point where working from home is becoming difficult:
https://www.speedtest.net/result/10085597251
Should I just call to report a fault?
Kind regards,
Matthew
  • 2.94K
  • 226
  • 630
Trouble shooter
Message 5 of 13
@Originlabs wrote:
Hi Zak,
Kind regards,
Matthew
As Mike has already stated, the Upstream Power is too high and will need an engineer to fix.  Also there is a lot of noise on the circuit, as shown by the huge PostRS error count, and the fact one Upstream has dropped to 16 QAM to try and cope with this noise.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 13
Originlabs
  • 5
Message 7 of 13
Hi Mike,
I set one up a couple of weeks ago:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/efe3c366ae184798db26225d66cb95e409...
I've just tried calling support, but couldn't get past the automated line "we've tested your connection, and you need to reboot your hub.  If you're still having issues, please check our online support options". 😩
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 13
Your >> BQM << is showing dropped packets even though the latency isn't anything out of the ordinary.
At the top of the next hour can you do a reboot using this exact method please. This will put a time stamp on your BQM and also hopefully put your Pre & Post RS Errors back to zero. In an ideal world they will stay at zero so keep an eye on them ...
Switch the Hub off for 5 minutes using the small switch on the rear of the Hub next to the power cord.
Allow the Hub a few minutes to fully restart then check the error count.
John_GS
  • 8.76K
  • 477
  • 775
Message 9 of 13
Hi Originlabs
Thanks for posting. My apologies for the delayed reply.
I've checked and no issues are showing. I do hope everything has been resolved, please let us know if you need further assistance.
Kind regards,
John_GS
Originlabs
  • 5
Message 10 of 13
Hi John,
Unfortunately I'm still seeing upload speeds drop to near zero (< 1Mbps) at various times during the day.
The Pre RS and Post RS errors are still increasing, and Upstream Power (dBmV) is still at 5.1, which a previous commenter said was the maximum and required an engineer to resolve.
Kind regards,
