mdbray66
  • 56
  • 5
Message 1 of 10
Portslade speed
I'm supposed to be on 350, but since July this has been my regular download speed, 95. This is data from my Sam Knows box that i've kept going.
Any suggestions, the hub is in modem mode and has been rebooted.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 10
Re: Portslade speed
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
mdbray66
  • 56
  • 5
Message 3 of 10
Re: Portslade speed
i'll give this a go when i get home, thanks
mdbray66
  • 56
  • 5
Message 4 of 10
Re: Portslade speed
Network LOG
30/09/2020 05:06:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/09/2020 21:12:17ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/09/2020 12:40:58criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/09/2020 07:16:8Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/09/2020 07:16:4criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/09/2020 07:16:3Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/09/2020 07:16:3criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 09:12:17ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2020 17:49:58criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2020 04:34:46ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/09/2020 23:45:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/09/2020 08:19:45ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/09/2020 08:19:43ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/09/2020 19:26:58criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
mdbray66
  • 56
  • 5
Message 5 of 10
Re: Portslade speed
Downstream
1202750000240256 qam9
22107500001.940256 qam10
32187500001.740256 qam11
42267500001.540256 qam12
52347500001.440256 qam13
6242750000140256 qam14
72507500000.740256 qam15
82587500000.740256 qam16
92667500000.440256 qam17
102747500000.240256 qam18
112827500000.540256 qam19
122907500000.740256 qam20
13298750000140256 qam21
14306750000140256 qam22
153147500001.240256 qam23
163227500001.440256 qam24
174027500002.540256 qam25
184107500002.440256 qam26
194187500002.540256 qam27
204267500002.740256 qam28
214347500002.740256 qam29
224427500002.540256 qam30
234507500002.540256 qam31
244587500002.540256 qam32
1Locked40.9300
2Locked40.3400
3Locked40.3300
4Locked40.9400
5Locked40.9310
6Locked40.9290
7Locked40.9570
8Locked40.3860
9Locked40.3620
10Locked40.3680
11Locked40.3530
12Locked40.3580
13Locked40.9560
14Locked40.3660
15Locked40.9750
16Locked40.3590
17Locked40.9760
18Locked40.91490
19Locked40.3750
20Locked40.31060
21Locked40.91630
22Locked40.9880
23Locked40.91410
24Locked40.91480
mdbray66
  • 56
  • 5
Message 6 of 10
Re: Portslade speed
Upstream
1326000004.5512064 qam4
2536999464.575512064 qam1
3394000004.525512064 qam3
4462000004.525512064 qam2
3ATDMA0000
4ATDMA0000
Anonymous
Not applicable
Message 7 of 10
Re: Portslade speed
I'm assuming you are using your own router with the HUB being in modem mode?
Could you try the HUB in router mode to confirm you are getting the same speeds?
The speed you are reporting is around the 100Mbps link speed limit, which could be a bad ethernet cable.
mdbray66
  • 56
  • 5
Message 8 of 10
Re: Portslade speed
yes, hub 3 is in modem mode. i have an asus router.
i'll try it in router mode and also try another cable.
thanks for your help
mdbray66
  • 56
  • 5
Message 9 of 10
Re: Portslade speed
thanks everyone for the help.
by a process of elimination i discovered that it was the ethernet cable from my router to the samknows box that was the fault.
Paul_DN
  • 6.35K
  • 363
  • 659
Message 10 of 10
Re: Portslade speed
Hi mdbray66,
Thank you for reaching out to us and for the update, really glad to hear you have managed to resolve this yourself by changing the Ethernet cable.
Regards'
Paul.
