on 22-08-2023 20:51
Have ran the app and one bedroom WiFi is very poor identified as 15Mb
Can I request a WiFi pod booster please
on 23-08-2023 08:05
Hi @Elizabeth-2023 👋.
Thanks for reaching out to us. Apologies that you have been having issues with signal strength in your home, we can certainly assist you in obtaining a WiFi Max pod. We would need to bring you in for a private message.
Please look out for the envelope on the top right of your web browser or if you are using a mobile device, it will be located under your profile icon.
Thanks.
Sabrina
on 24-08-2023 18:30
I believe the pod I am getting has an ethernet port, or 2 can I use this to connect to my printer
