deanb01
  • 13
Message 1 of 19
Poor upload speed
Had 200/20 broadband installed a couple of months ago and up until Thursday 11th June was getting a consistent 210-220 download and 20 upload. The router went offline on Thursday for about 15 minutes, and when it came back on my upload speed had dropped to around 7. Download speed is still fine.
First CS rep was very helpful and sent an engineer out the following day. He noted there was noise on the line, which was also noted on the router diagnostics.
There appear to be no reported faults, my broadband is still stuck on 7 upload, and CS are not being very helpful in resolving this. It is not my home network (have tested router with no other connections other than an Ethernet cable), and the speed does not fluctuate. It's as if some system has decided that's the maximum speed I can now get.
I don't want to call CS again - partially deaf, so struggle with phone conversations.
Is anyone able to assist on here?
Tags (3)
deanb01
  • 13
Message 2 of 19
Re: Poor upload speed
Is anyone from Virgin on this forum able to help?
gary_dexter
  • 30.24K
  • 1.87K
  • 4.02K
Message 3 of 19
Post the Network, Upstream and Downstream logs from the hub admin pages
David_Bn
  • 4.87K
  • 223
  • 397
Message 4 of 19
Good Afternoon dean01,
Thanks for your post on our Community Forums and a very warm welcome to you!
Sorry to see you've been having issues with your upload speeds? Is this on Wired as well as Wi-Fi?
I've looked at the stats of the hub and everything appears to be within spec
Kindest regards,
David_Bn
deanb01
  • 13
Message 5 of 19
Thanks for the replies.
An engineer was out the other day and confirmed there is no fault with the line. I had my hub connected with no other devices and was only getting 7.9 on the upload. He plugged in another hub into my line on a 300 account and it was getting a steady 330/35Mbs. It's as if my account has been set up to only do 220/8 as opposed to 200/20.
Stats are below:
402750000
Locked
Ranged Upstream Channel (Hz)
25800000
Locked
Provisioning State
Online
deanb01
  • 13
Message 6 of 19
14027500003.538256 qam30
22027500007.540256 qam9
32107500006.940256 qam10
42187500006.440256 qam11
5226750000640256 qam12
62347500006.340256 qam13
72427500006.540256 qam14
82507500006.940256 qam15
9258750000740256 qam16
10266750000740256 qam17
112747500006.640256 qam18
122827500006.140256 qam19
132907500005.640256 qam20
14298750000540256 qam21
153067500004.440256 qam22
163147500004.440256 qam23
173227500004.340256 qam24
183307500004.540256 qam25
193707500004.640256 qam26
203787500004.338256 qam27
213867500003.740256 qam28
223947500003.540256 qam29
234107500003.538256 qam31
244187500003.538256 qam32
1Locked38.9510
2Locked40.3360
3Locked40.3310
4Locked40.3190
5Locked40.3260
6Locked40.9180
7Locked40.9180
8Locked40.3280
9Locked40.9230
10Locked40.9220
11Locked40.9390
12Locked40.3230
13Locked40.3490
14Locked40.3490
15Locked40.3550
16Locked40.3630
17Locked40.3670
18Locked40.3400
19Locked40.3540
20Locked38.6490
21Locked40.3760
22Locked40.3620
23Locked38.9420
24Locked38.9600
deanb01
  • 13
Message 7 of 19
1258000004.1512064 qam12
2537000004.175512064 qam13
3326000004.125512064 qam11
4394000004.125512064 qam10
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
rkldJKDHSUBsgvca69834ncxv9873254k;
SFID265
Max Traffic Rate230000061
Max Traffic Burst4000
Min Traffic Rate0
Primary Upstream Service Flow
SFID264
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
Alex_RM
  • 4.28K
  • 247
  • 325
Message 8 of 19
Thanks for getting back to us deanb01.
Can you confirm if you've performed a pin hole reset since the technician visit.
Alex_Rm
deanb01
  • 13
Message 9 of 19
No. This is the first I've heard of this. I will try tomorrow and will let you know if that improves matters.
Megan_L
  • 2.36K
  • 146
  • 234
Message 10 of 19
Hiya Dean,
thanks for following our advice. Has this had any affect on your connection?
Megan_L
