Jamie-T
  • 26
Message 1 of 15
Poor upload and wifi
Hi All,
Anyone know why the 100mbs connection upload speed has dropped to 0.5 mbs from 6mbs and the download has dropped to 50mbs? It's been like it all week on wired and wireless.
ALSO: wifi signal seems to be super bad over the last 3 days with no changes our home at all. No extra devices or settings changes.
I'm talking about pure connection to the hub, not just the poor internet speeds.
Hub as been factory reset (the full 40 seconds hold not the 5 second)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 2 of 15
Re: Poor upload and wifi
Please do this before posting the Hub Data
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 3 of 15
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Please do not use screen shots.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 4 of 15
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
Jamie-T
  • 26
Message 5 of 15
Latency
30.3 ms
Jitter
9.37 ms
Download
112 Mbps
Upload
1.42 Mbps
Tags (1)
Jamie-T
  • 26
Message 6 of 15
11390000006.136256 qam1
21470000005.836256 qam2
31550000005.636256 qam3
41630000005.536256 qam4
51710000005.336256 qam5
61790000004.636256 qam6
71870000004.336256 qam7
81950000003.936256 qam8
92030000003.235256 qam9
102110000002.535256 qam10
112190000001.935256 qam11
122270000001.235256 qam12
132350000000.235256 qam13
14243000000-134256 qam14
15251000000-134256 qam15
16259000000-0.235256 qam16
172670000000.935256 qam17
182750000002.736256 qam18
192830000004.436256 qam19
202910000004.637256 qam20
21299000000536256 qam21
223070000005.137256 qam22
233150000005.537256 qam23
24323000000637256 qam24
1Locked36.613017917432
2Locked36.37205276744
3Locked36.310160446834
4Locked36.310185847309
5Locked36.337956110457
6Locked36.67462142419
7Locked36.6952148017
8Locked36.32218146937
9Locked35.71445148851
10Locked35.7235926
11Locked35.733152209
12Locked35.574144960
13Locked351915738
14Locked34.94312648
15Locked34.92872557
16Locked35.5912505
17Locked35.542152204
18Locked36.3145961
19Locked36.646841108789
20Locked37.37696578426
21Locked36.632468118662
22Locked37.37673978510
23Locked37.311322541958
24Locked37.614076413674
Tags (1)
Jamie-T
  • 26
Message 7 of 15
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
13940000043.5512064 qam4
24620000043.8512064 qam3
32580000044.3512064 qam6
43260000043.8512064 qam5
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1ATDMA0010
3ATDMA0000
4ATDMA0000
Tags (1)
Jamie-T
  • 26
Message 8 of 15
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057-b.cm
SFID378058
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID378057
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Tags (1)
Jamie-T
  • 26
Message 9 of 15
Network LogTime Priority Description
15/01/2021 12:22:9Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 12:22:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 12:22:5Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 12:22:5criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 11:44:9noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 11:43:56Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 11:32:35Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 11:26:39noticeSW download Successful - Via Config file
15/01/2021 11:24:22noticeSW Download INIT - Via Config file
12/01/2021 19:00:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 09:47:9ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/01/2021 21:07:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 21:47:9ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 22:49:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/01/2021 14:51:12ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/01/2021 09:57:5criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/2021 15:43:3ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 07:01:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 16:53:23ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Tags (1)
Jamie-T
  • 26
Message 10 of 15
1000Ethernet
Tags (1)
