HalpMeee
  • 11
Message 1 of 18
Poor speeds (for a 500Mbit connection) in the evenings
I've noticed that maybe over the past week, the DL speeds of my supposed 500Mbit connection reduce substantially in the evenings and tend to hover around the 50Mbit mark. When tested earlier in the mornings when I sign on for work, I see speeds up to 550Mbit. Uploads are consistent at around 35Mbit, no matter the time of day.
As some people get significantly lower speeds than this, I almost feel guilty raising the issue, but then I remember I'm paying north of £60 a month for BB-only and then the guilt disappears.
I can't provide the ThinkBroadband deets yet, as I've only just set that up.
Info from my Hub 3 are posted below:
HalpMeee
  • 11
Message 2 of 18
Re: Poor speeds (for a 500Mbit connection) in the evenings
Cable Modem Status
Item                                       Status          Comments
299000000
Locked
Ranged Upstream Channel (Hz)
60300002
Locked
Provisioning State
Online
HalpMeee
  • 11
Message 3 of 18
Channel       Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
12990000008.940256 qam21
21390000008.940256 qam1
3147000000940256 qam2
4155000000940256 qam3
51630000009.143256 qam4
6171000000940256 qam5
7179000000940256 qam6
8187000000940256 qam7
91950000008.940256 qam8
102030000008.840256 qam9
112110000008.540256 qam10
122190000008.640256 qam11
132270000008.540256 qam12
142350000008.843256 qam13
152430000008.843256 qam14
162510000008.843256 qam15
172590000008.640256 qam16
182670000008.540256 qam17
192750000008.440256 qam18
202830000008.343256 qam19
212910000008.540256 qam20
22307000000940256 qam22
23315000000940256 qam23
24323000000943256 qam24
1Locked40.990
2Locked40.9150
3Locked40.950
4Locked40.9220
5Locked43.3320
6Locked40.9250
7Locked40.9220
8Locked40.9210
9Locked40.9200
10Locked40.9190
11Locked40.9120
12Locked40.9100
13Locked40.9120
14Locked43.350
15Locked43.3130
16Locked43.3100
17Locked40.970
18Locked40.970
19Locked40.9180
20Locked43.3140
21Locked40.980
22Locked40.9130
23Locked40.9160
24Locked43.380
HalpMeee
  • 11
Message 4 of 18
16030000240.8512064 qam1
23940009739.3512064 qam4
34620000040.8512064 qam3
45369994440.8512064 qam2
1ATDMA0010
2ATDMA0010
3ATDMA0000
4ATDMA0000
Anonymous
Not applicable
Message 5 of 18
1Locked40.990
2Locked40.9150
3Locked40.950
4Locked40.9220
5Locked43.3320
6Locked40.9250
7Locked40.9220
8Locked40.9210
9Locked40.9200
10Locked40.9190
11Locked40.9120
12Locked40.9100
13Locked40.9120
14Locked43.350
15Locked43.3130
16Locked43.3100
17Locked40.970
18Locked40.970
19Locked40.9180
20Locked43.3140
21Locked40.980
22Locked40.9130
23Locked40.9160
24Locked43.380
Your downstream power levels are a touch high, but in spec (-6 to +10 is in spec, 0dB considered optimal).
Could you please create a BQM (Broadband Quality Monitor) here, and post the live link?
HalpMeee
  • 11
Message 6 of 18
Worth pointing out that any speed tests I carry out are on a wired connection.
Also I'm using the VM Hub 3 in modem-only mode and using my own router
HalpMeee
  • 11
Message 7 of 18
Live link is here
Anonymous
Not applicable
Message 8 of 18
@HalpMeee wrote:
Live link is here
The BQM isn't working.
Could you trying creating it again?
HalpMeee
  • 11
Message 9 of 18
I realised I had ICMP echo replies disabled in my router's firewall. I've enabled the replies now; hopefully that should show more meaningful info...😬
Anonymous
Not applicable
Message 10 of 18
Ah, didn't realise you were using your own router!
Yes, it is showing now. We'll need to leave if for an hour or so.
