umpa
  • 29
Message 1 of 15
Poor speed
Since upgrading to 1Gb my speed is worse than when I was on M500. My speed is usually now below 500Mb where with the M500 it was 510Mb.
I see speed as low as 400Mb to a maximum of 700Mb (very rare) and neither of these speeds are acceptable to me.
I have tried in router mode and modem mode.
When I test the system VM gives me this error :-
Sorry, we can’t run a test on your services right now
Tags (2)
  • 1.83K
  • 113
  • 420
Super solver
Message 2 of 15
Re: Poor speed
With the Hub in Router mode try :  https://www.samknows.com/realspeed/
umpa
  • 29
Message 3 of 15
Re: Poor speed
What country is that site for ?
It does not work for me in modem mode or router mode.
It reports :-
RealSpeed is not available on this network
Tags (1)
umpa
  • 29
Message 4 of 15
Re: Poor speed
Here is a pic from my routers own inbuilt speed test.  This is direct from the modem to my router via cat 6. No other switch or device.
Tags (1)
  • 1.83K
  • 113
  • 420
Super solver
Message 5 of 15
Re: Poor speed
UK Hubs in Router mode can use:  https://www.samknows.com/realspeed/
  • 13.87K
  • 1.07K
  • 2.81K
Message 6 of 15
Re: Poor speed
Have you got any QoS or packet processing set in your own router. What is the router?
umpa
  • 29
Message 7 of 15
Re: Poor speed
hi,
Its a AX11000mMU-MIMO tri-band gaming router.
I have tried all the QOS settings, and turned it off completely.
It has to be the modem as that is the only variable that has changed.
umpa
  • 29
Message 8 of 15
Re: Poor speed
Also to add when in router mode, it is not even connected to my gaming router and the speed is still crap - giving the same speeds.
umpa
  • 29
Message 9 of 15
Re: Poor speed
That link does now work for me. FWIW I have a super hub 5.
carl_pearce
  • 1.76K
  • 113
  • 377
Super solver
Message 10 of 15
Re: Poor speed
Are you using the HUB 5's 2.5 Gbps port with the Asus's 2.5Gbps WAN port?
