maullah
  • 20
Message 1 of 10
Poor speed on 350m package
Hello,
Have been with Virgin for 15+ years and usually very good speed and service. I am experiencing several problems over last 1 month that I was hoping would go away but seems like that is not happening.
My setup: Hub 3 in Modem mode connected to PC with CAT6, 350M package
Problems:
1) Often speed below 250M, dropping down below 90M at times, specially in the evenings
2) Very high ping when speed is low
3) Significant throttling of non Virgin Media Usenet server connections which was not seen before March 2020
I would appreciate if someone could check out the issues please. Also, any idea when 1G package would be available in Bedford? Many Thanks.
MU
gary_dexter
  • 30.46K
  • 1.89K
  • 4.05K
Message 2 of 10
Re: Poor speed on 350m package
What other router are you using if you’re in modem mode?
maullah
  • 20
Message 3 of 10
Asus RT-AC3200
Firmware version 3.0.0.4.382_52230
gary_dexter
  • 30.46K
  • 1.89K
  • 4.05K
Message 4 of 10
what speed do you get wired direct to the hub without the router?
maullah
  • 20
Message 5 of 10
Here are a couple of speed tests while my PC is directly connected to Hub3 by Cat6.... no router in the loop. Look at the variability of ping and speed with in a few minutes. Is there some network problem going on in the Virgin Media network?
gary_dexter
  • 30.46K
  • 1.89K
  • 4.05K
Message 6 of 10
Post the network, upstream and downstream logs from the hub admin pages
maullah
  • 20
Message 7 of 10
Here they are...
The network log is a bit messy. Sorry.
Time
Priority
Description
03/06/2020 19:35:2
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:31
critical
03/06/2020 16:47:27
notice
02/06/2020 18:05:37
Error
DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/06/2020 03:55:49
critical
29/05/2020 17:02:32
Error
DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/05/2020 14:04:21
Error
29/05/2020 12:02:25
critical
29/05/2020 05:09:59
Error
28/05/2020 18:43:8
critical
28/05/2020 17:17:29
Error
26/05/2020 05:59:50
critical
25/05/2020 02:12:31
Error
23/05/2020 23:21:2
Error
23/05/2020 08:22:18
critical
19/05/2020 20:52:31
Error
18/05/2020 21:34:7
Error
15/05/2020 14:16:56
critical
15/05/2020 08:06:49
Error
14/05/2020 04:44:55
Error
maullah
  • 20
Message 8 of 10
Well, any clues from the logs?
maullah
  • 20
Message 9 of 10
No one here from Virgin Media to help? So many similar complaints about speed. What's going on?
gary_dexter
  • 30.46K
  • 1.89K
  • 4.05K
Message 10 of 10
A mod will respond to it when they can
Bumping the post just pushes it to the bottom of the todo pile
