RSM123
Poor speed and daily disconnecting
I have been on the supposed 500mb package for months now, and never got more than 220. Within hours of restarting laptop and modem it will drop to as low as 40. I got better speeds and consistency on my previous package.
For the last week my connection has dropped every single night. On several occasions the 345 1111 number has stated there is an intermittent fault, or a fault in the local area.
If I cannot have what I am paying for then I want to be put on my old speed and my costs cut.
£63 pounds a month for this is not right.
RSM123
Re: Poor speed and daily disconnecting
I cannot post a screenshot but the VM online test page states
"Looks like there is an intermittent signal issue in your area."
This has been the case for 5 days.
  • 35.1K
  • 3.41K
  • 6.68K
Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues down to postcode level.
RSM123
According to the automated service status line there are no issues, yet here
https://care.virginmedia.com/care/check-services
It says -  Looks like there’s still an issue with your connecti
We’re looking into it. Check back here after 6 hours and if there’s still an issue we’ll help you book an engineer
Can I actually get some help finding out why my speeds are less than half the 500mb, and why my service disconnects every night ?
  • 35.1K
  • 3.41K
  • 6.68K
A VM person will respond on here in a few days - in the meantime call retentions and they will be able to sort it once you tell them you are calling to cancel the service.
Call it in on 150 (VM Phone - free) or 0345 454 1111 (any other phone - national rate). Use options 1,1,4,4, “thinking of leaving” - they usually pick those calls up quickly and the retentions are UK based
Calling at 08.00 midweek (09.00 Sun) is the best time to get through quickly - but at busy/closed times you may get redirected to offshore - hence calling early is best.
Serena_C
  • 2.19K
  • 91
  • 215
Hi @RSM123
Welcome to our Community Help Forum 🙂
Thank you for making your first post regarding the connection issues you've been experiencing, I'm sorry to hear you've been getting sluggish speeds. That is not ideal.
I would like to take a look further into this for you, I shall send you a private message to obtain the details required now. Please look out for the purple envelope in the top right corner and get back to me when you can.
Kind regards,
Serena
