stephenrn
  • 8
Poor speed (Hub 3, MK42)
I woke up without Internet this morning, and got service back after restarting the Hub, but am only seeing speeds of 80-100Mbps down and, more painfully, around 2Mbps up. Tested with a wired connection directly to the hub. I'm on the M350 package and normally see 350+ down and 35+ up.
The Post-RS error rate does seem high as I understand it.
Thanks in advance.
11710000005.940256 qam5
21390000005.140256 qam1
31470000005.140256 qam2
41550000005.840256 qam3
5163000000640256 qam4
61790000005.339256 qam6
71870000004.640256 qam7
81950000005.140256 qam8
92030000005.540256 qam9
102110000005.440256 qam10
112190000004.640256 qam11
12227000000440256 qam12
13235000000440256 qam13
142430000003.940256 qam14
15251000000440256 qam15
162590000004.340256 qam16
172670000005.340256 qam17
182750000005.140256 qam18
192830000004.940256 qam19
202910000004.640256 qam20
212990000004.640256 qam21
223070000004.540256 qam22
23315000000540256 qam23
243230000005.540256 qam24
1Locked40.9393104375095
2Locked40.3520951709952
3Locked40.9706522340891
4Locked40.3624253522693
5Locked40.9396737701253
6Locked40.9220756424715
7Locked40.9422013294676
8Locked40.3321278138394
9Locked40.932434477780
10Locked40.91436528476
11Locked40.32416098942
12Locked40.9441863166108
13Locked40.3420337178996
14Locked40.942857210571
15Locked40.93465919985
16Locked40.944943237327
17Locked40.3246287219624
18Locked40.932654495809
19Locked40.3152524180
20Locked40.91475561197
21Locked40.318010892584
22Locked40.921690747121
23Locked40.92930342
24Locked40.35658459
16030000047.5512064 qam1
25370000047.3512064 qam2
34619973746.8512064 qam3
43940027845.8512064 qam4
1ATDMA0010
3ATDMA0000
4ATDMA0010
Alex_RM
  • 6.63K
  • 342
  • 498
Re: Poor speed (Hub 3, MK42)
Hi stephenrn,
Thanks for posting, and sorry to hear you've had some issues with your connection.
I've been able to locate your account using your forum details, and everything looks to be within the specifications we would expect.
Are you having any connection issues at the moment?
Alex_Rm
snakebiteuk
  • 13
HI, ive had three years of this, Ive just posted, mine was the cabinet, major ingress of water into the cables.
Hope this helos.
  • 6.08K
  • 511
  • 1.57K
You should reboot the Hub so the counters are zeroed.  Keep an eye on the PostRS errors, ideally there should be none.  If the numbers increase quickly after the reboot, there is an issue in the circuit despite what VM have advised.
Check all the connections from the Hub to outside are "finger" tight, as loose connections can cause noise ingress.
You power levels look okay at present.  Also setup a BQM here  www.thinkbroadband.com/ping
Once setup post a link to the shared graph for comment.
stephenrn
  • 8
Thanks for checking Alex_RM, and sorry for the slow reply. Over the course of a few hours things began to speed back up until they were back to normal and have been fine since.
Stephen
David_Bn
  • 8.54K
  • 359
  • 664
Thanks for the update @stephenrn
Do please let us know if you require any further assistance
Kindest regards,
David_Bn
