tuneup
  • 14
Message 1 of 9
Poor quality broadband/packet loss
Hi there, I have been struggling with poor quality broadband for a few months now. The speed drops to nothing and on occasions the online speed tests can't complete. If I try to do something data intensive the connection can loose the plot with packet losses all over the place and it will take a while to recover. Using the internet after a period of inactivity has a similar affect where it chuggs its way into action.
I expect it is due to the amount of people on the same line as me locally but it is becoming unusable at times. I do a lot of VoIP and the packet losses are a real pain.
When I contact vm for help it of course works fine when they do their tests. Can I get them to monitor over a period of time. It is frustrating going through the basic restarts, turn it off and on etc. every time I contact the help line.
I have attached some monitoring I have done over the past couple of weeks
Any advice or help would be much appreciated.
gary_dexter
  • 30.29K
  • 1.88K
  • 4.03K
Message 2 of 9
Re: Poor quality broadband/packet loss
Post back (as text) the network, upstream and downstream logs from the hub admin pages
tuneup
  • 14
Message 3 of 9
Thanks for you response.
Downstream
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
435000000
4.3
38
256 qam
36
2
235000000
3.5
37
256 qam
13
3
243000000
3.4
37
256 qam
14
4
251000000
3.7
37
256 qam
15
5
259000000
3.7
37
256 qam
16
6
267000000
3.9
37
256 qam
17
7
275000000
3.9
37
256 qam
18
8
283000000
3.2
37
256 qam
19
9
291000000
3.5
37
256 qam
20
10
299000000
3.7
37
256 qam
21
11
307000000
3.7
37
256 qam
22
12
315000000
4.1
37
256 qam
23
13
323000000
4
37
256 qam
24
14
347000000
4.3
37
256 qam
25
15
355000000
4.5
37
256 qam
26
16
363000000
4.9
37
256 qam
27
17
371000000
4.6
37
256 qam
28
18
379000000
5.1
37
256 qam
29
19
387000000
5
37
256 qam
30
20
395000000
4.9
38
256 qam
31
21
403000000
5.4
38
256 qam
32
22
411000000
5
38
256 qam
33
23
419000000
4.6
37
256 qam
34
24
427000000
4.8
38
256 qam
35
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.6
40
0
2
Locked
37.6
40
0
3
Locked
37.3
86
0
4
Locked
37.6
37
0
5
Locked
37.6
79
0
6
Locked
37.6
44
0
7
Locked
37.6
32
0
8
Locked
37.6
72
0
9
Locked
37.6
51
0
10
Locked
37.6
49
0
11
Locked
37.6
58
0
12
Locked
37.6
29
0
13
Locked
37.3
68
0
14
Locked
37.6
95
0
15
Locked
37.6
27
0
16
Locked
37.6
40
0
17
Locked
37.6
60
0
18
Locked
37.6
31
0
19
Locked
37.6
53
0
20
Locked
38.6
59
0
21
Locked
38.6
27
0
22
Locked
38.6
52
0
23
Locked
37.6
49
0
24
Locked
38.6
20
0
Upstream
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
60300007
4.35
5120
64 qam
1
2
39399988
4.175
5120
64 qam
4
3
46199998
4.2
5120
64 qam
3
4
53700002
4.35
5120
64 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
gary_dexter
  • 30.29K
  • 1.88K
  • 4.03K
Message 4 of 9
Nothing untoward there to indicate any drops etc.
Whats dropping exactly and on what devices?
tuneup
  • 14
Message 5 of 9
Everything, wired and wifi devices. VoIP calls, webpages and streaming will all drop at the same time, all on different devices.
Gareth_L
  • 6.1K
  • 374
  • 657
Message 6 of 9
Hi tuneup
Do we still need to have a look at this drop out
Has it still happened since your post
Gareth_L
tuneup
  • 14
Message 7 of 9
Hi Gareth, thanks for your response. Yes I am still having some issue though it does seem a little better than it was during peak periods.
Gareth_L
  • 6.1K
  • 374
  • 657
Message 8 of 9
Hi tuneup
Thanks for the reply
Still not perfect though, so on this basis.
I have booked the first engineer appointment we have available
You can check and reschedule this appointment through your online account if you need to
You can also cancel it if the fault has gone
Can you please let me know how the visit goes
Gareth_L
tuneup
  • 14
Message 9 of 9
Thank you Gareth
