Hemingway1975
  • 11
Message 1 of 17
Poor and intermitent speeds
Well its been going on since I joined virgin. Im on their 350mbps package and I have had the old chesnut..we have monitered your speeds etc and we carnt find a issue. It must be you etc.  But every time I check their speeds its so intermittent, wired connection mbps
1st check 135download, 9.7 upload
2nd chech 213download, 2.6 upload
3rd check 36download, 5 upload
4th check 280 download 8.9 upload
5th check 160 download 9.8 uplaod
Every time I check its totally different, I could check every minute and totally different readings. Their is no consistency to my broadband. I never get more than 10 upload, but yet im promised up to 30. Its a joke that they have monitered and its found no faults etc. My wired connection is no longer than 6 metres. I will definatly be going back with bt when my contract is up. Yes I can only get 60mbps etc. But when I was with them it never ever dropped below 54 upload and 19 download. It was so consistant with them, I went with virgin for the thought they had sorted them selves out from last time I had a contract with them. But how wrong I was....
Alex_D1
  • 77
  • 8
  • 8
Message 2 of 17
Re: Poor and intermitent speeds
ive messaged you regarding some details to try resolve the issue.
In the meantime
Log in to the Hub.
192.168.0.1
Insert hub password (8 digits long)
Also, you can set the 2.4G and 5G to manual, changing the 2.4g to channel 6 or 7 and 5G to.channel 36 or 40.
If still having problems split the wifi -
Advanced Settings > Wireless > Security > Add '-2G' to the 2.4GHz Channel name > Add '-5G' to the 5 GHz Channel name > Click ‘Apply Changes’
Log out of the Hub.
You will need to reconnect all your Wi-Fi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
2.4GHz is a stronger signal but slower than 5GHz.
Hemingway1975
  • 11
Message 3 of 17
I will look at this when I get home. These are the readings through my lan cable connection. Wireless is o.k as I just use mobiles for wireless and its enough. All my devices are connect through ethernet cables.
jem101
  • 1.62K
  • 229
  • 756
Message 4 of 17
To be honest, I wouldn't bother with the above, if you are getting those results over ethernet then that is pointing to a circuit issue rather than wifi. Log into the hub and post up the connection stats for the upstream and downstream along with the logs.
Hemingway1975
  • 11
Message 5 of 17
Havent had chace to check yet, will this weekend. Internet just been poor as usual
Hemingway1975
  • 11
Message 6 of 17
I don’t know what I’m supposed to up load. I have taken a few picks and picks of my PS4 5-6 test over 30 seconds. You can see how intermittent it is. If you need more just let me know
gary_dexter
  • 30.39K
  • 1.88K
  • 4.04K
Message 7 of 17
A console isn’t an accurate way to speedtest.
Eeeps
  • 753
  • 47
  • 118
Rising star
Message 8 of 17
What is being asked for is the modem status pages that may help identify possible issues.
Connect to your SH3 web interface on 192.168.0.1. If you've logged in before the just click the link at the bottom of the page.
Don't take snapshots just copy an paste the formatted text.
Hemingway1975
  • 11
Message 9 of 17
Yes I know, ps4 is using ethernet cable, but even still this should be showing a decent consistency. When I had bt 60 download and 20 upload I always checked through ps4 and it was always between 50-60 download and 17-20 upload. It never dropped everytime I checked, that was over a two year period. So surley I should be still seeing consistency at least to the pics supplied.
Hemingway1975
  • 11
Message 10 of 17
When I try to copy and paste it only copies the digits and then puts them in a different format in here. not lined like in the formatted boxes. Do you require the info from the network status pages for Bonded channels for upload and download. When I paste it puts in down like the message is 150 lines long downwards
