Hils22
  • 19
Message 1 of 8
Poor and erratic speeds after upgrade from 100 to 200
Recently upgraded (15th November) from Mixit to Maxit but speeds and connections have been erratic, both on wired and non wired.  Have reset router several times but still poor.  I am not technical and no nothing about routers modems etc but I have taken some screen shots of router status but not sure how to send through?? Speed this morning was 64 downstream/20 upstream. Our son is working and needs reliable speed, so can anyone please help?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 8
Re: Poor and erratic speeds after upgrade from 100 to 200
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 8
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Hils22
  • 19
Message 4 of 8
Downstream  DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)411000000419000000427000000435000000443000000451000000459000000467000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID12345678
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)0.821.011.311.672.132.102.382.44
RxMER (dB)35.4235.6035.6035.9736.1736.1736.8436.39
Pre RS Errors103377320393021931000134813171101
Post RS Errors230120651818128359210261006762
Hils22
  • 19
Message 5 of 8
Upstream  US-1 US-2 US-3 US-4
Channel Type2.02.02.02.0
Channel ID5346
Frequency (Hz)32600000462000003940000025800000
Ranging StatusSuccessSuccessSuccessSuccess
Modulation64QAM64QAM64QAM64QAM
Symbol Rate (Sym/sec)5120000512000051200005120000
Mini-Slot Size2222
Power Level (dBmV)43.5043.2543.2543.75
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts3020
T4 Timeouts0000
Hils22
  • 19
Message 6 of 8
General Configuration
Network AccessAllowed
Maximum Number of CPEs1
Baseline PrivacyEnabled
DOCSIS ModeEuroDOCSIS 3.0
Config File
SFID1069640
Max Traffic Rate230000061 bps
Max Traffic Burst42600 bytes
Min Traffic Rate0 bps
Primary Upstream Service Flow
SFID1069639
Max Traffic Rate22000061 bps
Max Concatenated Burst42600 bytes
Scheduling TypeBest Effort
Hils22
  • 19
Message 7 of 8
First TimeLast TimePriorityError NumberDescription
01/12/2020 05:42:02 GMT01/12/2020 05:42:02 GMTCritical (3)82000200No Ranging Response received - T3 time-out
01/12/2020 05:39:28 GMT01/12/2020 05:39:28 GMTCritical (3)82000200No Ranging Response received - T3 time-out
01/12/2020 05:21:59 GMT01/12/2020 05:21:59 GMTCritical (3)82000200No Ranging Response received - T3 time-out
01/12/2020 04:33:36 GMT01/12/2020 04:33:36 GMTCritical (3)82000200No Ranging Response received - T3 time-out
01/12/2020 04:32:49 GMT01/12/2020 04:32:49 GMTCritical (3)82000200No Ranging Response received - T3 time-out
30/11/2020 21:19:21 GMT30/11/2020 21:19:21 GMTError (4)68010302DHCP WAN IP - 86.1.161.10
30/11/2020 21:18:23 GMT30/11/2020 21:18:23 GMTError (4)68000407TOD established
Time Not EstablishedTime Not EstablishedNotice (6)84000510Downstream Locked Successfully
30/11/2020 13:13:02 GMT30/11/2020 13:13:02 GMTError (4)68000407TOD established
Time Not EstablishedTime Not EstablishedError (4)68000408TOD initialise failed
Time Not EstablishedTime Not EstablishedError (4)68000406TOD server unavailable
Hils22
  • 19
Message 8 of 8
Hi thanks for suggestion about BGM but will look at that later  but have posted all other data
