Elvoski
  • 36
Message 1 of 65
Poor Wifi coverage and Poor cable speeds
Since having VM Broadband installed a few months back, I had slow speeds, connectivity drops and poor wifi coverage.
I have spoken to the guys in Customer Service a number of times and each time they make changes to my wifi settings and tell me that will fix it - it never does and then can never get though to anyone to move onto the next steps, always the same thing when I call up.
I do not trust using the recommended speedtest.net as this defaults to their servers and does not give a real world test.
I desperately need a WIFI booster or 2 as my mobile data is taking an absolute hammering.
I am supposed to be getting 600Mbps and no less than 315Mbps according to VM.
600Mb using VM SuperHub 3.0
If I have helped you in one way or another, please consider hitting that Kudos button 🙂
My Broadband Ping - VM Proof
cje85
  • 2.78K
  • 178
  • 756
Trouble shooter
Message 2 of 65
Re: Poor Wifi coverage and Poor cable speeds
Speedtest.net doesn't have any Virgin Media servers anymore, it would be useful to see a test from that site, or www.nperf.com or www.fast.com just to see if they show  the same speed.  The TBB test has a habit of reporting slower speeds that aren't reflected in other speed tests (or real downloads)
Elvoski
  • 36
Message 3 of 65
Thanks for the reply.
Speedtest.net - Hits the speed I should be getting then steadily drops to...
Fast.com
conman33158
  • 1.67K
  • 134
  • 364
Super solver
Message 4 of 65
Also try https://speedtest.samknows.com/
It's pretty dependable most of the time 🙂
BT Full Fibre 900 FTTP - Asus RT-AX82U to Openreach ONT Box & Asus RT-AX56U with AiMesh setup
Elvoski
  • 36
Message 5 of 65
again, way below what it should be.
conman33158
  • 1.67K
  • 134
  • 364
Super solver
Message 6 of 65
What are your speeds via wired connection. If it's just wifi that's suffering you would probably be better of with your own third party router or mesh system 🙂
Elvoski
  • 36
Message 7 of 65
That is cabled..
conman33158
  • 1.67K
  • 134
  • 364
Super solver
Message 8 of 65
Can you please upload your router stats and we'll see if that shows anything?
Type 192.168.0.1 or (192.168.100.1 if you have your Hub in Modem mode) into your address bar at the top of your browser
DO NOT LOG IN, just click “Check Router Status” at the bottom of the page. Sometimes the “Check Router Status” is missing, in this case just go ahead and log in and go to Advanced Settings-> Tools-> Network Status.
Please copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs, if you get a yellow warning just click the Post button again.
You can use more than one post for each item if needed!
If you get a warning when you hit “Post” just hit “Post” again and it should work ok!
Please do not use screenshots
Elvoski
  • 36
Message 9 of 65
1267000000-2.238256 qam17
2139000000038256 qam1
31470000000.740256 qam2
4155000000038256 qam3
5163000000-0.238256 qam4
6171000000040256 qam5
7179000000038256 qam6
8187000000138256 qam7
91950000000.238256 qam8
10203000000-238256 qam9
11211000000-0.738256 qam10
12219000000038256 qam11
13227000000038256 qam12
14235000000-0.238256 qam13
15243000000-0.738256 qam14
16251000000-1.238256 qam15
17259000000-1.738256 qam16
18275000000-2.438256 qam18
19283000000-2.738256 qam19
20291000000-1.938256 qam20
21299000000-1.238256 qam21
22307000000-1.238256 qam22
23315000000-138256 qam23
24323000000-138256 qam24
1Locked38.91389173672
2Locked38.919476127846
3Locked40.315170114343
4Locked38.915665130076
5Locked38.625076106597
6Locked40.331615110311
7Locked38.92599798590
8Locked38.92574895830
9Locked38.927966106082
10Locked38.930760104944
11Locked38.92181494735
12Locked38.91323285565
13Locked38.91186275453
14Locked38.91201668098
15Locked38.91147672025
16Locked38.61187273380
17Locked38.91340776968
18Locked38.91506280614
19Locked38.92762185093
20Locked38.93259485649
21Locked38.92500971753
22Locked38.91858972312
23Locked38.61448371850
24Locked38.91256872519
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
16030000047.3512064 qam1
23939998644.5512064 qam4
34620000044.8512064 qam3
45370005045.8512064 qam2
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1ATDMA00120
2ATDMA0070
3ATDMA0060
4ATDMA0080
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt078+voc-b.cm
Elvoski
  • 36
Message 10 of 65
continued...
SFID180978
Max Traffic Rate690000278
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID180977
Max Traffic Rate44000278
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
06/04/2021 13:47:33noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/04/2021 18:12:57criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2021 02:13:41ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/03/2021 11:05:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/03/2021 14:13:40ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/03/2021 04:59:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/03/2021 01:13:39ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/03/2021 07:29:24criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/03/2021 01:13:37ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/03/2021 22:16:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/03/2021 19:01:58noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/03/2021 23:53:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/03/2021 16:58:18Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/03/2021 13:13:36ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/03/2021 09:04:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/03/2021 01:13:35ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/03/2021 09:47:33Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/03/2021 09:47:28criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/03/2021 09:45:59Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/03/2021 09:45:59criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
