nicbrt
  • 5
Message 1 of 11
Poor Upload speed - please help
Hi All,
Reading posts here I see many are having the same issue, I have been struggling recently to have a solid connection, even sitting next to my router connection drops and gets interrupted.
I have upgraded the account to M350 but I get 3Mbps at most, very frustrating as I cannot even have online meeting without the connection dropping.
Any help would be welcome please!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 11
Re: Poor Upload speed - please help
I take it you are using a Wi-Fi connection ?
What is your connection like with a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
nicbrt
  • 5
Message 3 of 11
Yes I do use wifi.
I did try once with the ethernet cable and the speed was up to 50Mbps, however as I am in a flatshare we cannot all use the cable and we are all on wifi.
Can this be a router issue or more on the virgin side?
I tried all their recommendations but haven't seen any improvement
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 11
To start with you need to use a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected  to ensure that you are getting the correct speed to the Hub, can you do that please ?
nicbrt
  • 5
Message 5 of 11
Sure, I've plugged my PC with a cable and i got 7.31 Mbps download and 7.71 Mbps upload.
Is this what you are looking for?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 11
OK
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
nicbrt
  • 5
Message 7 of 11
The live link is:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/fbe21bad4dbc738dface3479c8550857e1...
Here the Downstream, Upstream and Network Log:
1402750000-8.536256 qam25
2194750000-6.537256 qam8
3202750000-6.736256 qam9
4210750000-736256 qam10
5218750000-7.236256 qam11
6226750000-7.236256 qam12
7234750000-7.736256 qam13
8242750000-7.736256 qam14
9250750000-836256 qam15
10258750000-836256 qam16
11266750000-836256 qam17
12274750000-836256 qam18
13282750000-8.236256 qam19
14290750000-836256 qam20
15298750000-836256 qam21
16306750000-7.736256 qam22
17314750000-7.936256 qam23
18322750000-7.536256 qam24
19410750000-8.736256 qam26
20418750000-936256 qam27
21426750000-936256 qam28
22434750000-9.236256 qam29
23442750000-9.236256 qam30
24450750000-936256 qam31
ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
1603000754.6512064 qam6
2461999564.55512064 qam8
3393999914.525512064 qam9
4536998364.575512064 qam7
TimePriorityDescription
01/01/1970 01:07criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/09/2020 21:13criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/09/2020 21:11Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/09/2020 21:11Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/09/2020 21:11criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/09/2020 11:07ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/09/2020 19:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/09/2020 07:56noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 10:25noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/08/2020 22:09criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/08/2020 09:14noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/08/2020 03:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/08/2020 12:30noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2020 10:57criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2020 01:18ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2020 23:30ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2020 23:16noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 11
Your Downstream Power Levels are far too low (Min - 6dBmV) and will require an engineer to put them right.
You can contact VM to report the problem using ...
Text service on 07533051809
150 from Virgin landline.
0345 454 1111 from any other UK  phone.
The best time to call is weekdays 08:00 to get a UK agent, anything after 10:00 you must realise that you are quite likely to get through to an offshore agent that doesn't speak English as a first language.
Or you can wait on here for one of the VM Staff to pick up the thread but this may take a few days.
nicbrt
  • 5
Message 9 of 11
Many thank for your help Mike, will try and give a call if i don't hear from anyone on this post for a few days.
Juts a question on the offshore agent, will they still be able to sort (hopefully) the issue or does the engineer you mentioned need to come physically?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 11
It needs a physical engineer.
