UnhappyCamper67
  • 11
Message 11 of 18
Re: Poor Speed in both Wifi and Ethernet - Hub 4 and 1GB sub
Here you go...........
https://www.thinkbroadband.com/speedtest/1614370990570492355
Thanks for your help btw, much appreciated.
JitteryPinger
  • 1.86K
  • 207
  • 385
Super solver
Message 12 of 18
Is that using the deco system or hub wifi?
If I've helped let me know 🙂
10 year's managing 9 Virgin Media accounts, and things never got any better, closed last 4 accounts since January 2021 :L
I give 'my' experience to help where possible.
UnhappyCamper67
  • 11
Message 13 of 18
That's using the Deco system with the Hub in modem mode.
JitteryPinger
  • 1.86K
  • 207
  • 385
Super solver
Message 14 of 18
I've found the problem, the Deco system your using has a 100mbps limit on the Ethernet ports, so unfortunately I would return them in exchange for a different model.
https://www.tp-link.com/uk/home-networking/deco/deco-e4/#specifications
UnhappyCamper67
  • 11
Message 15 of 18
Ah ok, so if I take the Hub off of modem mode and use the Deco system purely as wifi extenders the speed should go up?
JitteryPinger
  • 1.86K
  • 207
  • 385
Super solver
Message 16 of 18
Yes, I also recommend trying to get your desktop connected using a Cat6/6a cable to give you that added performance.
UnhappyCamper67
  • 11
Message 17 of 18
Thanks for your help Mark, much appreciated. Looks like I'll have to buy the Deco with the 1GB ethernet connection, then link up the E4s.
JitteryPinger
  • 1.86K
  • 207
  • 385
Super solver
Message 18 of 18
Yeah, are you not able to return the E4's then, the one you would be looking for would be the M4 to match your current pair or maybe buy one with a big more grunt in it as the main router (to handle the 1Gb) and then pair the E4's.
This is the recommended one https://www.tp-link.com/uk/home-networking/deco/deco-m5/v2%20(1-pack)/
Can be brought here https://www.amazon.co.uk/Deco-M5-Coverage-Replacement-Antivirus-white/dp/B073XQ3YND/ref=sr_1_4?dchil...
