ManiacMatt
  • 51
Message 1 of 12
Poor Speed / Online Gaming Lag - BQM Attached
Hi guys,
As above I have been having poor download and upload speeds lately which I have noticed since the start of lockdown.
I have also started doing some online gaming again which I haven't for years really but I am experiencing lag.
I am on the 350mb download package.
The Superhub 3 is connected in modem mode to an Asus RT-AX88U router running Merlin firmware via a VPN.
To be clear if I remove both the VPN and/or Asus router from the equation this doesn't seem to make any difference so I am confident that the problem is with the Virgin broadband itself.
Please see my BQM below - Can anyone help please?
I have actually considered paying for Gig1 fibre but don't think that this would actually help as perhaps there is a fault with the line somewhere?
Any help is much appreciated.
Matt
-Matt
BQM monitor:My Broadband Ping - Virgin Gig1
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 12
Re: Poor Speed / Online Gaming Lag - BQM Attached
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
ManiacMatt
  • 51
Message 3 of 12
Hi Mike,
Thank you for your help please see below:
Downstream
14190000005.837256 qam32
22030000007.438256 qam9
3211000000738256 qam10
42190000006.538256 qam11
5227000000637256 qam12
62350000005.337256 qam13
72430000005.337256 qam14
82510000005.537256 qam15
92590000005.537256 qam16
102670000005.437256 qam17
112750000005.337256 qam18
122830000005.537256 qam19
132910000005.837256 qam20
14299000000637256 qam21
153070000006.137256 qam22
163150000006.437256 qam23
173230000006.637256 qam24
183630000006.437256 qam25
193710000006.137256 qam26
203790000006.137256 qam27
213870000005.937256 qam28
22395000000637256 qam29
234030000005.937256 qam30
24411000000637256 qam31
1Locked37.6820
2Locked38.6150
3Locked38.6200
4Locked38.9170
5Locked37.6190
6Locked37.6390
7Locked37.6310
8Locked37.6290
9Locked37.6300
10Locked37.3310
11Locked37.6350
12Locked37.6340
13Locked37.6330
14Locked37.3520
15Locked37.6500
16Locked37.3380
17Locked37.6120
18Locked37.6340
19Locked37.3390
20Locked37.3500
21Locked37.6760
22Locked37.6740
23Locked37.3750
24Locked37.3710
Upstream
1536999694.05512064 qam4
2461999574.05512064 qam3
3394000173.9512064 qam2
4326000583.9512064 qam1
3ATDMA0000
4ATDMA000
0
-Matt
ManiacMatt
  • 51
Message 4 of 12
network log
01/09/2020 08:19:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 17:32:40noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 17:32:40ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 11:39:46ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 09:22:0criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 09:22:0criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 06:37:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/08/2020 18:01:16ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/08/2020 13:30:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2020 13:17:51Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2020 13:17:46Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2020 13:17:46criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2020 13:17:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2020 13:07:9Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2020 13:07:5criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2020 13:07:4Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2020 13:07:4criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
-Matt
ManiacMatt
  • 51
Message 6 of 12
If anyone can help me it would be much appreciated - I know it has only been a week since I have posted but I'm not sure how long it usually takes for a mod to look into?
-Matt
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 12
They are very good BQMs for a VM Broadband line.
This is mine, my lad uses it for online gaming without any problems. The lost packets are forced reboots to check some settings.
BQM-01
Paul_DN
  • 6.32K
  • 363
  • 659
Message 8 of 12
Hi Matt,
Thank you for reaching out to us in our community, I am sorry to hear you are having issues with your connection, I have checked thing our end and cannot see any issues at all, your levels are all where they should be.
Also looking at your quality reports everything looks OK.
Paul.
  • 16.3K
  • 711
  • 1.6K
Message 9 of 12
Doing any downloading or uploading can cause ping spikes or you have something bad on your network doing a DoS or are by DoS.
ManiacMatt
  • 51
Message 10 of 12
Hi guys,
Thank you for looking at this and commenting it is appreciated.
This is my BQM from the last 24 hours - As it was Sunday my brother was trying to play Counter-strike yesterday but his ping kept spiking to 1200!  I don't think any of my devices would have auto downloaded for the full 4pm to 2am period or 6am onwards this morning so not sure what this could be?
https://www.thinkbroadband.com/broadband/monitoring/quality/share/c95f1d263812c93ad0e012be8b0fc4af83...
-Matt
