  • 82
Message 1 of 10
Poor Connection since M500 upgrade
Since I was upgraded to M500 the speeds and stability haven't been as good as M350, I see lots of posts about this same issue on here.
I have a samknows white box monitoring the connection here, and I have a TBB broadband ping monitor running, and I can see massively increased latency and timeouts on the monitor.
I havent called faults because they wont understand the problem, and will go though rebooting the hub and doing pointless speedtests that are to a server within the VM network.
Can one of the mods take a look at this and escalate to someone in the right team to look at?
I faced similar issues that were resolved for a few days earlier this month, I have the logs and graphs showing the poor performance.
Graphs below.
Today
Today Weds 22/01Today Weds 22/0108/01 just after service outage08/01 just after service outage
Speed test today.
https://www.thinkbroadband.com/speedtest/1579697100744828255
  • 17.3K
  • 1.82K
  • 3K
Message 2 of 10
Re: Poor Connection since M500 upgrade
Just a quicky..... I dont use Samknows but this was an issue for this user - does it apply to you ?
https://community.virginmedia.com/t5/Speed/Vivid-350-speed/td-p/3941298
  • 82
Message 3 of 10
Yes they swappped the whitebox once I advised them of my service change to M500.
Thanks anyway!
  • 4.35K
  • 739
  • 1.77K
Message 4 of 10
"Since I was upgraded to M500 the speeds and stability haven't been as good as M350, I see lots of posts about this same issue on here."
Probably because the harder you push a piece of equipment, the less fault tolerance it has.  We know from comment in these forums that VM did some end user field tests up to about 690 Mbps with the Hub 3, and I'm guessing that performance wasn't reliable enough to achieve a 750 Mbps speed tier, hence the gap between 500 and 1 Gig offers (where available).  Even at 500 Mbps, I suspect that's really stretching the hub, and anything slightly flakey could tip performance over the edge.  But that won't be what your "all yellow" BQM is showing, I would be fairly confident that's a cable or network issue, and it is so bad I'd guess that VM know about it, and hopefully there's plans in place to fix it.
  • 82
Message 5 of 10
Looks like its getting worse...
  • 4.35K
  • 739
  • 1.77K
Message 6 of 10
Have you had a look for evidence of a cable fault in your hub status page?  Connect to your hub, don't log in, but click "Check router status", then have a look at the tab "Network logs".  If that's full of recent critical errors with words like T3 timeouts, and/or Synchronisation error, and/or RCS Partial service, and/or No ranging response, then your cable connection probably has a fault.  All messages like DHCP Rebind or Renew can be ignored, and if there's a few critical errors, but not more frequent than every four days of so, then that of itself doesn't confirm that there is or is not a fault..
And whilst you're you're in Router status, take a look at the tab "Downstream".  There should be 24 channels, each with SNR values above 34 dB, and power levels should be between -5 dBmV and +10 dBmV, (ideally tightly clustered and closer to 0 is better than at either limit).  Error numbers should be low for pre-RS errors, but as they count continuously since the last on/off cycle, its difficult to give advice without knowing what the error count is and when the hub was last power cycled.  If there's any number of post-RS errors then there has been some form of serious trouble, but obviously we need to know when the hub was last restarted.
Next, look at Upstream.  The power levels (as the hub shows them) should be between 3.4 dBmV and 4.9 dBmV, there should be four channels, all of them should be shown as running at 64 QAM.  If this is not the case, then there's some form of upstream noise that interrupts the synchronisation of hub and street cabinet, but that usually appears to customers as poor downstream performance.
  • 82
Message 7 of 10
Stats Below.
1323000000-5.238256 qam24
2251000000-2.740256 qam15
3259000000-340256 qam16
4267000000-2.740256 qam17
5275000000-3.240256 qam18
6283000000-3.540256 qam19
7291000000-3.940256 qam20
8299000000-440256 qam21
9307000000-4.540256 qam22
10315000000-4.938256 qam23
11371000000-6.738256 qam25
12379000000-7.238256 qam26
13387000000-7.538256 qam27
14395000000-7.938256 qam28
15411000000-838256 qam29
16419000000-8.238256 qam30
17427000000-8.438256 qam31
18435000000-8.738256 qam32
19443000000-938256 qam33
20451000000-9.237256 qam34
21459000000-9.237256 qam35
22467000000-9.537256 qam36
23475000000-9.538256 qam37
24483000000-9.537256 qam38
1Locked38.97001520395
2Locked40.35239920762
3Locked40.312151723072
4Locked40.36003921955
5Locked40.94292723885
6Locked40.33454518846
7Locked40.33895619318
8Locked40.33994812476
9Locked40.34850112688
10Locked38.96232413370
11Locked38.98246317419
12Locked38.910016942423
13Locked38.914113520601
14Locked38.617056119784
15Locked38.616323515574
16Locked38.916992519127
17Locked38.918231519040
18Locked38.620508518248
19Locked38.619730817737
20Locked37.621850716616
21Locked37.626078617415
22Locked37.633460011259
23Locked38.638719012945
24Locked37.640664519587
1462000004.425512064 qam1
2258000534.125512064 qam7
3325999954.225512064 qam3
4394000204.325512064 qam2
3ATDMA0000
4ATDMA0000
  • 82
Message 8 of 10
23/01/2020 15:12:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/01/2020 20:00:10ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/01/2020 21:20:23Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2020 00:53:5ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2020 01:00:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2020 01:35:33Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2020 03:07:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2020 03:19:33ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2020 05:46:4ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2020 06:28:55criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2020 07:59:35criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2020 07:59:35Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2020 07:59:36criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2020 07:59:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2020 07:59:40Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2020 08:46:57criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2020 10:00:28Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2020 11:51:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2020 12:26:3Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2020 14:34:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 4.06K
  • 190
  • 320
Message 9 of 10
Thanks for your posts philce.
Sorry to see you've been having broadband issues, this is likely to see a closer look and possibly an engineer to visit your property
Please check out the purple envelope in the top right hand corner for a PM from me
Kindest regards,
David_Bn
  • 82
Message 10 of 10
Looks like things are going wrong again!
Just to confirm, this is a new problem over the last week or so, up to now not seeing any major issues since the kids are home trying to break the connection!
TBB graph today. Speeds also suffering on Sam knows testing.
Hub stats after a reboot.
12590000000.740256 qam16
21390000005.840256 qam1
31470000005.540256 qam2
4155000000540256 qam3
51630000004.940256 qam4
61710000004.840256 qam5
71790000004.540256 qam6
8187000000440256 qam7
91950000003.740256 qam8
102030000003.240256 qam9
11211000000340256 qam10
122190000002.740256 qam11
13227000000240256 qam12
142350000001.740256 qam13
152430000001.240256 qam14
16251000000140256 qam15
172670000000.540256 qam17
18275000000040256 qam18
19283000000-0.240256 qam19
20291000000-0.540256 qam20
21299000000-0.940256 qam21
22307000000-1.540256 qam22
23315000000-1.540256 qam23
24323000000-1.938256 qam24
1Locked40.9100
2Locked40.350
3Locked40.3160
4Locked40.360
5Locked40.900
6Locked40.360
7Locked40.350
8Locked40.360
9Locked40.960
10Locked40.350
11Locked40.3220
12Locked40.390
13Locked40.3200
14Locked40.360
15Locked40.990
16Locked40.370
17Locked40.380
18Locked40.390
19Locked40.3100
20Locked40.3190
21Locked40.3110
22Locked40.3130
23Locked40.3180
24Locked38.9130
1462000004.1512064 qam1
2326000003.925512064 qam3
3394000004.025512064 qam2
4258000003.825512032 qam7
3ATDMA0000
4ATDMA0000
