JohnMorr
  • 32
Message 1 of 14
Poor Broadband speed
Notice over a few days now that the internet & emails speed is slow and tested as max 20Mbps which is way down from previous speeds (100Mbps).  Nothing has changed in the house (previous similar post November 2020) which could affect the broadband speed.  Just on the point of renewing contract with Virgin Media.
  • 6.79K
  • 590
  • 1.78K
Message 2 of 14
Re: Poor Broadband speed
@JohnMorr wrote:
Notice over a few days now that the internet & emails speed is slow <snip>
Try checking with Area faults on 0800 561 0061 or if you have a VM landline 150 as small local faults are not listed on the VM status page.
Also post the power levels and network log.  Setup a BQM here www.thinkbroadband.com/ping
Once done we can comment on your circuit.
Gareth_L
  • 11.45K
  • 635
  • 1.25K
Message 3 of 14
Hi JohnMorr
Thanks for your post
I have checked a few things from here and its all looking okay
Has the connection settled down since you last post
Gareth_L
JohnMorr
  • 32
Message 4 of 14
Hi Gareth.
Just checked to Speed - 25.45 & 22.49 Mbps using Speedtest by Ookla - The Global Broadband Speed Test.
Not toward nor near 100 Mbps?
Only my laptop is on!
JohnMorr
  • 32
Message 5 of 14
carl_pearce
  • 1.76K
  • 113
  • 375
Super solver
Message 6 of 14
@JohnMorr wrote:
Hi Gareth.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/a8044888cf4740fa7bbba2b13a23649862...
BQM looks fine.
Have you tested on a wired device?
JohnMorr
  • 32
Message 7 of 14
Not tonight as other thinks to do for week ahead.
BQM https://www.thinkbroadband.com/broadband/monitoring/quality/share/a8044888cf4740fa7bbba2b13a23649862... confirms Speed test. using 4G.
Tom_W1
  • 3.66K
  • 199
  • 343
Message 8 of 14
Hi @JohnMorr, thanks for your reply here in the community.
Unfortunately, we do not guarantee speeds via wifi as these are dependent on a lot of external factors (the device, the distance away from the router, the amount of devices you have online at one time etc).
Can you please report back once you've ran a speed test via an ethernet cable please?
Many thanks
Tom_W
JohnMorr
  • 32
Message 9 of 14
Hi Tom.
I am looking to use a 5G connection next week ( as now using 4g and told that will be far superior).
I will check with the cable to.
JohnMorr
  • 32
Message 10 of 14
I have upgraded the internet connection at my laptop and the speed is now close to the 100 Mps specified.
I have set up a new BQM -
https://www.thinkbroadband.com/broadband/monitoring/quality/share/1b9d5047eb452718fa2d4eb14ceea8854d...
Best regards
