Poor Broadband Speed Into House
00leel00
We have the 350Mbps package but Ethernet connection from router to laptop using speedtest.net shows only 100-150Mbps coming into the house. WiFi connection constantly drops out, Virgin came and split the 2.5GHz and 5GHz into 2 last March thinking that the connection was getting stuck between the two….hasn’t made any difference. Slow speeds to begin with are far below what we pay for. The whole thing needs someone looking at an overhauling. Otherwise we will be leaving. Our speeds are below the limit for exiting our contract without penalty!
22 REPLIES 22
Zak_M
Good morning 00leel00
Welcome to the forums and thank you for taking the time to post.
I am sorry to hear that you have had some issues with your broadband services.
Splitting the SSID wouldn't have an effect on the wired connection.
Are you able to let me know if the Ethernet cable is a CAT6 or above?
Kind regards,
Zak_M
00leel00
Yes it is a Cat6 cable
Zak_M
Thank you for coming back to me.
I have taken a look over things from here and I am unhappy with some of the status I am seeing.
I would like to get an engineer out to come and take a further look over things.
Are you happy for me to book that for you?
Kind regards,
Zak_M
00leel00
YES please.
Zak_M
No problem, I will pop you over a PM so that I can confirm your address.
Kind regards,
Zak_M
Zak_M
Thank you for providing me with that information via PM.
I have booked this appointment for you, for the time, date and make any further amendments you can visit your my virgin media account.
Kind regards,
Zak_
00leel00
Hiya,
where on my virgin media account does it tell me?
Zak_M
If you go to home > Help > orders and appointment.
Kind regards,
Zak_M
00leel00
the engineer was unable to fix it and said someone else would come in a couple of days. Can you tell me when this will be please and what the plan is?
