Hello, First time poster here!
I've recently upped my package to 350 from 100 because I was getting issues with devices not connecting and laggy/slow internet over wifi for my partners PC. Trying to do video calls was almost impossible if anyone else used the internet as it would freeze then all words come at once.. like it's some kinda of packet hold up! I called to cancel because I'd rather had broadband at 12Mbps with a stable connection than fast but intermittent speeds. I was told I was maxing out my bandwidth and should upgrade to a higher package... I mean I play games online and we watch Netflix etc. I also Stream my xbox to my PC but that uses LAN connection and not the internet.
So after the upgrade I bought an Archer C1200 gigabit router and put the virgin superhub 3 into modem mode because i'd consistently get lag spikes playing games. This could happen at any time not just during the day. I figured it's the hub not handling the traffic well. I also suspect the hub is intermittently faulty because the few times i've put it into modem mode sometimes I couldn't get WAN, sometimes I couldn't access it via 192.168.100.1 and had to hard reset.
I tried a few routers before the C1200 and all seem to give the same issue which is variation in ping. Using CMD I would ping 8.8.8.8 over a period of time and i'd get random spikes in latency from around 20ms to 100-400ms then back down and repeat then sometimes it's stable. I also have a broadband monitor (Yesterdays graph: https://www.thinkbroadband.com/broadband/monitoring/quality/share/87de7dbc554d5c34a679d1f1dd6564e77b... ) ignore if its says 100Mbps i've not updated it.
I've also done speedtest over LAN and sometimes it's really good hitting what I expect, sometimes it drops lower than the minimum. Again this varies depending on the day (to be expected) but surely this shouldn't affect a simple video call?
Is this a case of just being in an oversubscribed area and my connection to the exchange is fighting others? It seems like downloading stuff is fine but applications that require low ping (gaming, video calls) seem to be affected. I can only get fibre on Virgin as no other provider provides fibre... Guess I'm the only street in Greater London than Openreach decided to skip!
I'll not post my routers upstream and downstream unless requested so I don't have a massive post at the start. Any help or confirmation of my worries would be appreciated!
