Jiffers
  • 7
Message 1 of 7
Persistently slow speed WA1 4 area
We first noticed the slowing down of our B/B about a week ago.
we pay for 200GB and are only getting between 25 and 90 at present.
I’ve reset the Hub numerous times, with no change being seen.
is there a wider issue here?
Can anyone help to shine light ion what is happening ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 7
Re: Persistently slow speed WA1 4 area
How are you connecting your device[s], Wi-Fi or ethernet cable ?
Jiffers
  • 7
Message 3 of 7
Spoiler
Via Wi-Fi
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 7
Forget Wi-Fi for now.
What is your connection like using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Jiffers
  • 7
Message 5 of 7
Thanks for the message Mike.
Sadly, we have no items which can be connected in such a way. The hub is too far away from the only PC in the home.
All other devices (except TV and PVR) are connected via Wi-Fi. This has been the case ever since Virgin’s B/B was installed many years ago. Each year, VM have increased our speed (at a price, of course) and we have been delighted. Only over the past week or so have we seen a catastrophic reduction in speed.
We had thought that we were immune from seeing the dreaded “buffering” symbols on our tablets and phones. Sadly not.
cheers
Geoff
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 7
Without knowing the status of the broadband connection you will never know if it is a Wi-Fi problem; you could then spend good money on better Wi-Fi gear that isn't needed.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 7
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
