Fedup123456
  • 6
Message 1 of 8
Paying for up to 200M but getting less than 1M
Hi I have seen a lot of advice in here, but I don't have a computer/ethernet to do these things. I just do everything on my phone and tablet by WiFi.
As the title says, I am paying for 200M but my phone kept switching to mobile internet so I checked speed test.net and it was below 1M
I upgraded to this about a week ago, I was on 100M and getting over 70 most of the time. Why would upgrading kill my signal?  I have tried resetting the hub and also the pinhole reset.
just checked and it is 0.14 download and 17 upload
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 8
Re: Paying for up to 200M but getting less than 1M
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 8
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Fedup123456
  • 6
Message 4 of 8
My BQM
I hope I have done this right.
Typically, my broadband is not as slow today, but I just tested it and it is about 70
Fedup123456
  • 6
Message 5 of 8
Router status
Status
Downstream
1 227000000 0.9 38 256 qam 12
2 219000000 0.7 38 256 qam 11
3 235000000 1 38 256 qam 13
4 243000000 0.7 38 256 qam 14
5 251000000 1 38 256 qam 15
6 259000000 1.2 38 256 qam 16
7 267000000 1.2 38 256 qam 17
8 275000000 1 38 256 qam 18
9 283000000 1.2 40 256 qam 19
10 291000000 1.5 38 256 qam 20
11 299000000 1.5 38 256 qam 21
12 307000000 1 38 256 qam 22
13 315000000 1.5 38 256 qam 23
14 323000000 1.7 38 256 qam 24
15 331000000 1.7 38 256 qam 25
16 339000000 1.7 38 256 qam 26
17 347000000 1.7 38 256 qam 27
18 355000000 1.5 38 256 qam 28
19 363000000 1.4 38 256 qam 29
20 371000000 1.5 38 256 qam 30
21 379000000 1.7 38 256 qam 31
22 387000000 1.4 38 256 qam 32
23 395000000 1.7 38 256 qam 33
24 403000000 1.7 38 256 qam 34
1 Locked 38.6 129 0
2 Locked 38.6 109 0
3 Locked 38.9 54 0
4 Locked 38.9 180 0
5 Locked 38.9 226 55
6 Locked 38.9 201 0
7 Locked 38.9 121 0
8 Locked 38.9 98 0
9 Locked 40.3 133 0
10 Locked 38.9 49 0
11 Locked 38.9 95 0
12 Locked 38.9 98 0
13 Locked 38.9 54 0
14 Locked 38.9 46 0
15 Locked 38.9 59 13
16 Locked 38.9 49 0
17 Locked 38.9 31 0
18 Locked 38.9 32 0
19 Locked 38.9 69 0
20 Locked 38.9 62 0
21 Locked 38.9 200 1
22 Locked 38.6 193 234
23 Locked 38.9 215 15
24 Locked 38.9 66 0
Fedup123456
  • 6
Message 6 of 8
Upstream
1 53700000 47.3 5120 64 qam 6
2 60300000 47.5 5120 64 qam 5
3 46200000 46.5 5120 64 qam 7
4 39400000 46.3 5120 64 qam 8
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
Fedup123456
  • 6
Message 7 of 8
Password
Router status
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060+voc-b.cm
SFID172190
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID172189
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
Fedup123456
  • 6
Message 8 of 8
Welcome back!
Sign in to view or modify your Hub 3.0 settings.
Password
Router status
Status
Downstream
Upstream
Configuration
Refresh data
01/12/2020 21:18:31 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/12/2020 19:12:1 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/11/2020 21:29:17 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/01/1970 07:05:10 Error ToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/01/1970 07:04:59 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/1970 23:48:18 Error ToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/1970 23:46:49 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/1970 19:46:17 Error ToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/1970 19:46:7 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/1970 07:23:56 Error ToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/1970 07:22:59 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 05:30:24 Error ToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 05:29:7 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 05:29:4 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 05:29:1 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 05:29:1 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 05:28:58 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 04:54:56 Error ToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 04:51:55 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
