sweetleaf
  • 52
  • 7
Message 1 of 28
Paying for 350Mbps and getting below 100Mbps
So I have recently upgraded my connection from the 250Mbps plan to 350Mbps and now I am getting less that I used to!!!! Also the quality of the line is rubbish as my latency jumps from 35ms to 65ms down to 35ms and then back to 90ms!!!
Just have a look on the down/up speed from a speed test I took 1 min ago:
Tags (2)
  • 30.72K
  • 3.04K
  • 5.82K
Message 2 of 28
Re: Paying for 350Mbps and getting below 100Mbps
Try a Hub “pinhole reset” - make sure the 2 passwords on the Hub sticker are still there and legible first ! Disconnect any ethernet cables from the Hub (leave the coax connected), and then with the Hub still "switched on" throughout, press pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 seconds, release the pin, leave for 5’ to stabilise - dont manually switch it off at any time.
See if that sorts it.
Do the speedtests over an ethernet cable connected device
sweetleaf
  • 52
  • 7
Message 3 of 28
Hey @jbrennand,
Thank you for your advice but that didn't make much of a difference. I am pretty convinced this is an issue with the line that Virgin should debug similarly to all my previous issues with their broadband. The only time I might get the speed I am paying for is if I do a speedtest at 03:00am.
So I would ask from a Virgin stuff to DM me so they can check my line/area.
Thank you
lotharmat
  • 3.85K
  • 259
  • 724
Community elder
Message 4 of 28
VM should pick this up presently!
  • 30.72K
  • 3.04K
  • 5.82K
Message 5 of 28
Whilst waiting lets see what the connection looks like - try this.
____________________________________________________
Post up your Hub/network connection details and someone will check to see if there is a problem there.  In your browser’s URL box type in http://192.168.0.1  (or http://192.168.100.1 - if in modem mode) and hit return. On the first page up [there should be no need to login if you have done so before unless you have the New Hub4 when you do] click on the “router status” icon/text at bottom-middle of first page up and then copy/paste as “Formatted Text” (not images) 3 FULL sets of data onto here – 2 pages from the Downstream, 2 from the Upstream, & the Network Logs page. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again.
Also, in the meantime... If you haven’t already, set up a free and secure “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” to the “share live graph” (as per instructions on the TB website) when it starts to develop.
Zach_R
  • 3.45K
  • 115
  • 241
Message 6 of 28
Hi @sweetleaf,
Thank you for your posts and welcome back to our community forums. We're here to help.
I am really sorry to hear and see that you're having some speed issues lately. As I can't seem to see that you've specified in this thread (apologies if I've missed it), would you mind confirming if you're also having these problems on a wired connection? If you're yet to test a wired connection, can you please do so and confirm if the issue remains?
Zach - Forum Team
sweetleaf
  • 52
  • 7
Message 7 of 28
Hi @Zach_R,
The issue still remains. Tried a wired connection with no difference. I have attached the output of pinging to google[dot]com that show the timeouts on the connection and the increased latency.
Travis_M
  • 3.29K
  • 114
  • 243
Message 8 of 28
Hi @sweetleaf
I can see that there's currently an outage in your area with an estimated fix date of 05 JUL 2021 15:00
You may see this severely impacting your service at the minute, once this is concluded if the issues are still consistent then we'll investigate this further, but I believe the ongoing works should put a stop to this.
I've subscribed yourself to the outage updates so you're aware of when this is closed too.
Travis_M
sweetleaf
  • 52
  • 7
Message 9 of 28
Hey @Travis_M,
I am still nowhere near 350. Checking speed multiple times a day. Could you please confirm there are no more outages or anything?
Zoie_P
  • 4.45K
  • 186
  • 351
Message 10 of 28
Hi Sweetleaf,
Thanks for your reply, the outage is still ongoing, the estimated fix date is the 14th of July.
Zoie
