Nayyer
  • 6
Message 1 of 12
Pay for 350M receiving 50mb
Hi All,
       I am getting 5Mbps, 50mbps, 110mbps on a supposed 350M connection. Its fluctuating a lot never the same. Engineer came around, replaced internal cables, new hub, checked cabinet etc. Conclusion - drop cable dodgy. Apparently supposed to be fixed within 2 days - but this has not happened. What am I supposed to do now?joined on 24 August 2020 problem from the first day.
Buffer6
  • 10.46K
  • 92
  • 614
Hero
Message 2 of 12
Re: Pay for 350M receiving 50mb
Wait for one of the Forum team to get to your post
Lee_R
  • 2.56K
  • 136
  • 238
Message 3 of 12
Hi Nayyer, thanks for posting and welcome to our community.
I am sorry to hear you're having issues with your speeds you're receiving and the work required to resolve it has not yet been carried out. I would like to take a closer look into this for you. To enable me to do so, I am going to send you a private message. Please look out for the purple envelope in the top right of your screen.
Lee_R
Nayyer
  • 6
Message 4 of 12
I have answered you PM.
i raised a complaint and yesterday it was closed without resolving it. I am facing this problem from 24 august 2020. From 1st day i am having this problem the new date to put the cable is 24 September 2020. Wow whole month to resolve an issue
Nayyer
  • 6
Message 5 of 12
Now after changing the drop cable today it is not fluctuating but remains near 167mb to 220mb
Even with adsl cable is giving me 179mb checked several times.
what should i do.
Anonymous
Not applicable
Message 6 of 12
what should i do.
On a wired or wireless device?
Nayyer
  • 6
Message 7 of 12
Wired is 179mb
Anonymous
Not applicable
Message 8 of 12
@Nayyer wrote:
Wired is 179mb
Could you access your router using http://192.168.0.1/ or http://192.168.100.1 for modem mode . You shouldn't need log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs? Please copy/paste this data as text, split between multiple posts (Sometimes you have to click 'Post' twice due to an error message).
We can have a look for any oddities in the stats.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 12
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
Nayyer
  • 6
Message 10 of 12
